Migration from ESXi to Proxmox fails with "not enough space"
KronwarsCZ
Wed Jul 16, 2025 9:38 am
Hello everyone!
I am trying out Starwind V2V converter to convert VMs from old ESXi 6.5 to Proxmox 8.x, so far no luck :( . The vm in question is linux, 2 disks of 25 and 100 GB.
The issue I am facing is that the converter tries to create the disks on proxmox, but it fails with "not enough space". I fail to see how this is happening, since the target storage is "local-lvm" thin provisioned storage with 45 TB of space available. I tried to use both block and qcow2 migration options, but both fail with the same problem.
Does somebody face the same problem or can help?
Thank you for your help.
Wed Jul 16, 2025 9:53 am
Can you please share the conversion logs?
KronwarsCZ
Wed Jul 16, 2025 10:55 am
here are logs from the application.
Thanks for the quick reply :)
7/16 10:23:16.119 35a8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/16 10:23:16.135 35a8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.757
7/16 10:23:16.135 35a8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/16 10:23:16.135 35a8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/16 10:23:16.135 35a8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19045
7/16 10:23:16.135 35a8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 6b5f0000
7/16 10:23:22.088 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/16 10:23:36.589 302c Facility ???INFO: WrapperESXI::connect: m_url - URL
7/16 10:23:36.792 302c Facility ???INFO: WrapperESXI::connect: fullName - ucet na migrace, key - 521fd39e-234d-29fb-5f66-e2c7a280ff00
7/16 10:23:36.792 26b0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Worker thread started.
7/16 10:23:36.792 302c Facility ???INFO: VMConverter::ESXIConverter::Connection: No_timeout ESX connection
7/16 10:23:36.792 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/16 10:23:37.633 35a8 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.5.0
7/16 10:23:56.325 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/16 10:23:59.662 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
7/16 10:24:07.248 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Connect to Proxmox host
7/16 10:24:07.248 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetHostVersion: Get proxmox host version info
7/16 10:24:10.390 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetHostVersion: Get proxmox host version info
7/16 10:24:10.437 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::BuildVM: Get virtual machines lists
7/16 10:24:10.462 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetStorageContent: Get storage info lists
7/16 10:24:10.573 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetDiskPath: Get storage info lists
7/16 10:24:35.951 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetStorageContent: Get storage info lists
7/16 10:24:35.967 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetDiskInfo: Get disk information
7/16 10:24:36.263 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetDiskInfo: Get disk information
7/16 10:24:36.310 c30 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Successfully connected to proxmox host
7/16 10:24:36.310 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
7/16 10:27:17.298 35a8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/16 10:27:17.314 60c Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 15
7/16 10:27:17.314 18bc Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: CreateVM
7/16 10:27:17.314 18bc Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Set disks
7/16 10:27:17.314 18bc Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: disk name ide0, local-lvm:25.000000,format=qcow2
7/16 10:27:17.314 18bc Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: disk name ide1, local-lvm:100.000000,format=qcow2
7/16 10:27:17.314 18bc Facility ???ERROR: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Not enough space
7/16 10:27:17.314 60c Facility ???WARNING: CPPConverting::Convert: CANCEL
Wed Jul 16, 2025 1:59 pm
I just came up with this one.
Can you try converting the file to an intermediate host? It will need downtime because you will need to create the VM at the destination.
Could you please also tell me more about that 45 TB volume.
-how is it connected to the proxmox host?
-is it thin?
-does it support thin disks?
KronwarsCZ
Wed Jul 16, 2025 2:18 pm
Hi!
I am trying to convert the VM from esxi to local computer, which seems to be working. I can only convert the 25GB disk though, because I don't have much space left.
The 45TB volume is a RAID6 volume directly connected to the server via a RAID card. Proxmox reports it is LVM-Thin and it can store thin disks, as I already have several.
Maybe the V2V converter needs enough space on a local machine to migrate between these 2 hypervisors?
Wed Jul 16, 2025 2:44 pm
Thanks for checking!
Is there any chance for just an LVM (i.e., not thin)? I think this might be contributing to the problem.
No, V2V does not need space on the local machine.
KronwarsCZ
Mon Jul 21, 2025 9:25 am
Hello again!
I was unable to reply the last few days due to being rate limited.
I can absolutely confirm, that the storage "local-lvm" is LVM-Thin. If there is any other check, I can run it.
Screenshot 2025-07-21 at 11.21.39.png (8.47 KiB) Viewed 16020 times
Thank you again for trying to help :D
Mon Jul 21, 2025 8:08 pm
Thanks for your update. I have forwarded the input to the dev team. I am afraid you will need Proxmox Converter or converting to OVF for now.
Thanks for your help!
KronwarsCZ
Tue Jul 22, 2025 12:42 pm
Hi again!
I have wonderful news! I reinstalled the product with latest version and tried it again. This time I simplified even the name of the VM (just to be sure) and now it works. I sometimes run into an issue where the source ESXi will stop responding after each disk is converted, but clicking on Retry fixes it.
Thank you again.
Tue Jul 22, 2025 9:41 pm
Thanks for sharing. That's very weird. Yet, I am glad to read it works :)
