Error when connecting the server locally
ricardomacklin
Tue May 14, 2024 8:18 am
When I just try to connect locally (i.e. localhost or 127.0.0.1 or <machine name>), I get an error : " Cannot connect to the server. Username or password you entered is invalid."
I tried using Anonymous connection and not (i.e. logging in as admin w/admin password)
Any suggestions about the solution?
Tue May 14, 2024 2:28 pm
Welcome to StarWind Forum. I would assume that the script does not work, or you cannot connect to the StarWind Management console.
The default credentials for StarWindService are root/starwind
Let me know if that does not resolve an issue.
p.s. if you ever need to reset the password for Management Console reset viewtopic.php?f=5&t=5101&p=36175&hilit= ... ZDg#p36175
p.p.s. the default credentials for CVM TUI are swadmin/rds123RDS
