SW vSAN console is not high DPI aware
Benoire
Mon Mar 26, 2018 1:40 am
Hello
Just a quick one, my tablet has a high resolution and RDP'ing in to the VM that hosts a starwind installation causes the console to be screwed in terms of placement of text etc. Is the console High DPI aware? If you look at the screenshot I've attached, the menu in the middle is supposed to have the 3 options to create the various types of devices but its not visible. I can't install the console on this laptop as its not mine so I can't tell whether the console works at the native res without the RDP connection.
Chris
sw console.png (185.84 KiB) Viewed 15010 times
Tue Mar 27, 2018 2:06 pm
Can you provide me with more details on this?
- What is your resolution?
- What is the build you use when being able to reproduce this?
- Does this persist across Console restarts?
Benoire
Tue Mar 27, 2018 6:47 pm
Hi Boris
Resolution: 2736 x 1824
Build: 11818
The issue is that via RDP to the VM, the console is all screwed like the image as the RDP session follows the resolution of the PC it is being accessed from. If I directly access the VM via the vCenter console then its perfectly fine as the VM desktop resolution is pegged at 1920 x 1200.
Wed Mar 28, 2018 9:00 am
I will escalate this to my R&D and QA teams. Thank you for this information.
Benoire
Wed Mar 28, 2018 10:11 pm
Welcome. I would be happy to test but my test license expires in April so won't have console access.
Thu Mar 29, 2018 1:53 pm
After the new build is released, just drop me a message and we'll sort it out.
Benoire
Thu Mar 29, 2018 8:22 pm
Ok will do, glad to assist in making this software even better, its certainly working well for me!
Fri Mar 30, 2018 7:34 am
Just be sure to check https://www.starwindsoftware.com/release-notes-build from time to time for the information on availability of the new build.
