Starwind Console Crashing
vivek
Tue Sep 25, 2012 10:57 pm
I am using Starwind version 5.8.2059 with the HA license. I was able to create 19 HA stores with full sync, etc without any issues. However, I am not able to create the 20th store. Every time I go through the wizard to create an HA store, at the very last step before I can hit finish, the StarWind console crashes. I am not able to do anything on it until I reboot the entire server.
I have verified that all the NIC drivers are up to date and Windows is patched, etc. Is there a limit on the number of HA store that can be created? There is nothing in the logs that StarWind support was able to find :roll: that suggested any issue. Please help!!
Wed Sep 26, 2012 7:00 am
1) Please update to the most recent version of StarWind (V6)
2) Please give a try to 1) and if you'd experience the same issues we'd be happy to take a look at them :)
Thank you!
vivek wrote:I am using Starwind version 5.8.2059 with the HA license. I was able to create 19 HA stores with full sync, etc without any issues. However, I am not able to create the 20th store. Every time I go through the wizard to create an HA store, at the very last step before I can hit finish, the StarWind console crashes. I am not able to do anything on it until I reboot the entire server.
vivek
Wed Sep 26, 2012 5:43 pm
Thanks for the suggestion! I won't be able to perform an upgrade until next week because I still have stores that are not HA yet and need to schedule downtime. But is there a bug in the version I am currently on that would cause this issue? Because otherwise I am just wasting more time if I run into the same issue again after the upgrade!! Thank you!
Wed Sep 26, 2012 7:33 pm
Sure. Waiting for your feedback. Thank you!
vivek wrote:Thanks for the suggestion! I won't be able to perform an upgrade until next week because I still have stores that are not HA yet and need to schedule downtime. But is there a bug in the version I am currently on that would cause this issue? Because otherwise I am just wasting more time if I run into the same issue again after the upgrade!! Thank you!
vivek
Tue Oct 02, 2012 8:43 pm
For anyone who cares, this was caused by a license issue. The license was for 8 TB and the newest LUN I was provisioning took it over the 8 TB limit causing the the console to crash instead of showing an error. Starwind will look into improving that so that the console doesn't crash.
Tue Oct 02, 2012 11:20 pm
WOW
We'll check it out ASAP. Thank you for reporting!!!
vivek wrote:For anyone who cares, this was caused by a license issue. The license was for 8 TB and the newest LUN I was provisioning took it over the 8 TB limit causing the the console to crash instead of showing an error. Starwind will look into improving that so that the console doesn't crash.
alexey (staff)
Tue Oct 09, 2012 2:34 pm
vivek,
Could you pls upload .mdmp file from С:\Users\<username>\AppData\Roaming\StarWind\5\Console\ to some file hosting(mediafire or other) and send upload link to this email beta-testing@starwindsoftware.com.
Alexey Skotsyk
StarWind Software Inc.
vivek
Wed Oct 10, 2012 1:06 am
Hi
I have no such files in that location.
Thu Oct 11, 2012 1:31 pm
That is weird. Do you see any .mdmp files in StarWind installation folder?
