Starwind Proxmox repository timed out
ticktok
Thu Oct 02, 2025 8:54 pm
Woke up this morning to failed updates from my Proxmox hosts:-
Err:1 https://repo.starwind.com/proxmox master InRelease
522 <none> [IP: 104.21.35.130 443]
Reading package lists...
E: Failed to fetch http://repo.starwind.com/proxmox/dists/master/InRelease 522 <none> [IP: 104.21.35.130 443]
E: The repository 'http://repo.starwind.com/proxmox master InRelease' is no longer signed.
Hopefully this is a temporary issue.
Fri Oct 03, 2025 9:02 am
Yes, we know that the plugin can be throwing these messages. Thanks for pointing it nevertheless!
I just want to make sure I am reading it right: the plugin is obstructing the update due to being outdated.
Is there any way you can push through that warning?
ticktok
Fri Oct 03, 2025 10:24 am
No this is the Proxmox hosts daily check for updates and it is Starwind's repository server throwing the 522 error code.
Both Proxmox hosts and also trying the url in a browser it times out. Nothing to do with the local Starwind VMs providing shared storage.
Fri Oct 03, 2025 11:19 am
Got it. Thanks for your update!
Yes, that's the same old issue (I hope it gets fixed at some point). Many thanks for pointing it out.
andreasd
Fri Oct 17, 2025 4:51 pm
I am trying to install the Proxmox plugin... but the Proxmox repository still is unavailable. Are there plans to fix this?
Regards
Andreas
Sat Oct 18, 2025 6:44 am
There's some planned maintenance now.
Should be OK on WED.
CombFiltered
Tue Oct 21, 2025 5:25 pm
Is there a status page for this anywhere, or do I need to just keep retrying? I'm also waiting on this repo to be back up.
Tue Oct 21, 2025 5:57 pm
They seem to be working on the final touches on the build. Once the build is there, the repo should be available.
Sorry, can't give you the ETA; I hope it will be sorted until the end of this week.
