StarWind iSCSI SAN
Device mount failed after upgrading from RC1 to RC2
Postby khogan » Thu May 01, 2014 5:35 pm
I just upgraded to RC2 from RC1 and now I get a Device mount failed error on all lsfs volumes. I know this happened during a previous upgrade and the volumes needed to be recreated. Is this the same situation or did something go wrong?
Here is my last log http://pastebin.com/Ms61L9k4
khogan
Re: Device mount failed after upgrading from RC1 to RC2
Postby Bohdan (staff) » Mon May 05, 2014 3:49 pm
Analyzing the logs...
Bohdan (staff)
Postby khogan » Mon May 05, 2014 9:07 pm
Thanks, let me know if you need anymore info. I actually uninstalled RC2 and re-installed RC1 and the devices are all working again
khogan
Postby Alex (staff) » Wed May 07, 2014 7:01 pm
We have found the source of the issue, and working to fix it.
We touched device header structure during last month, and it became incompatible with RC1. It will be possible to switch to new build from RC1 without losing data when fixes are finished.
Alexey.
Alex (staff)
Postby khogan » Fri May 16, 2014 1:52 pm
I was wondering if this issue is fixed in the GA and if its safe for me to upgrade?
khogan
Postby anton (staff) » Mon May 19, 2014 5:55 pm
Supposed to be. You need to upgrade either way as we don't support Betas in production.
khogan wrote:I was wondering if this issue is fixed in the GA and if its safe for me to upgrade?
Return to Beta
Who is online
