Using V2v converter with Private Endpoint
LeslieRD
Thu Apr 25, 2024 12:29 pm
Hello ,
I have this scenario I would like to migrate some VMs from Azure to On-prem VMware is it possible to use your V2V converter with a private link through an Express Route Circuit ?
Thu Apr 25, 2024 2:02 pm
Welcome to StarWind Forum! Yes, as long as your ESXi and Azure instances can communicate conversion is possible.
LeslieRD
Thu Apr 25, 2024 3:08 pm
yaroslav (staff) wrote: ↑
Interesting so I'll have to configure correctly my On-prem DNS and route Table?
have you already implemented yet?
Thu Apr 25, 2024 3:17 pm
You need to ensure the communication. Unfortunately, I was never doing that (it seems to be part of the end-user world).
In most cases, I just converted a VM from my server to the cloud and vice versa. Give it a shot, maybe it works if you can communicate from your servers to Azure.
frederickolson
Thu May 21, 2026 9:46 am
It would also help to know:
Which V2V converter product/version you are using
Whether the Azure VMs are managed through Azure Migrate or native VMware tooling
The target VMware version/environment
