The format did not complete successfully
joshjacoby
Sat Mar 10, 2007 9:16 pm
I am using StarWind as an iSCSI target and StarPort as initiator on Windows 2003 server. I connect fine and see the drive in disk management but when I attempt to format the drive it goes for a while (counting % done) then will pop up an error "the format did not complete successfully".
The iSCSI drive is 120 GB. I saw a prior reference to conflict with Adaptec and disabled the Adaptec SCSI device but same result. Microsoft iSCSI initiator also has same problem. Any ideas?
Sat Mar 10, 2007 10:00 pm
If MS iSCSI initiator has the same problems - try play with installing/uninstalling different storage related software on your machine (like Veritas/Symantec/Roxio etc). It's all neither StarPort nor MS iSCSI initiator problem... Also please send us StarWind log. Thanks!
joshjacoby wrote:I am using StarWind as an iSCSI target and StarPort as initiator on Windows 2003 server. I connect fine and see the drive in disk management but when I attempt to format the drive it goes for a while (counting % done) then will pop up an error "the format did not complete successfully".
