Support for the NVMe / tcp and windows server 2025
Itzikr
Fri Jul 24, 2026 11:42 am
Hi
In case of an issue with the driver, who supports it, is there an sla for this?
Fri Jul 24, 2026 11:53 am
Welcome to StarWind Forum. May I ask what issue you are referring to?
Itzikr
Fri Jul 24, 2026 2:54 pm
Any potential issue
Let’s say Microsoft breaks something or the SAN it’s connected to , who’s owning the support for such a case?
Also, does the initiator support hyper-v as well or only bare metal windows server
Fri Jul 24, 2026 3:08 pm
That's quite vague...
If the problem is related to MS or the storage provider, the appropriate case needs to be logged with them. If the limitation is on their side, there's little we can do. Say, if the storage does not support reservation and therefore cannot be clustered over NVMe-oF, there's nothing we as an initiator vendor can do because the root cause is third-party hardware.
While StarWind's scope of support is limited only to our products, during break-fix support, we will do our best to stabilize our solution if the issue has happened due to a third-party product (e.g., MS Hyper-V or MPIO acting up). As a side note, if you have an active support contract, we might also help with the Windows-related side of the setup, but this should not be viewed as a general rule.
As a side note, You can install the StarWind NVMe-oF initiator in Windows Server or a desktop OS. Be it virtualized or bare-metal.
