vCenter - No items are listed
LHBL2003
Tue Jul 21, 2026 7:31 am
I have a vCenter:
Produkt: VMware vCenter Server
Version: 8.0.3.00900 (Previously tried with 8.0.3.00400)
Build-Nummer: 25413364
Regardless of whether I specify vCenter as the source or destination in V2V, no objects from vCenter are displayed.
On the same computer where V2V is installed, I can query all hosts, VMs, and datastores via the PowerShell CLI.
https://vcenter.MyDomain.local is also possible. There are no certificate error messages either.
Install-Module VMware.PowerCLI
Connect-VIServer vcenter.domain.local
Get-VMHost
Get-VM
Get-Datastore
I found this error in the V2V log. Unfortunately, I can't find any comparisons online.
7/21 8:40:36.861 5070 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/21 8:40:36.861 5070 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.848
7/21 8:40:36.861 5070 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/21 8:40:36.861 5070 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/21 8:40:36.877 5070 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 26200
7/21 8:40:36.877 5070 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 48d0000
7/21 8:40:41.699 5070 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/21 8:41:05.489 3ab0 Facility ???INFO: WrapperESXI::connect: m_url - https://vcenter.MyDomain.local/sdk
7/21 8:41:05.521 3ab0 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 52810799-0696-d163-6784-123456789123
7/21 8:41:05.521 22a8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_4eab79f5f0516eba86b7810fe0d8b684>::operator (): Worker thread started.
7/21 8:41:05.521 3ab0 Facility ???INFO: VMConverter::ESXIConverter::Connection: No_timeout ESX connection
7/21 8:41:05.521 5070 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/21 8:41:05.663 5070 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
7/21 8:41:05.663 5070 Facility ???ERROR: WrapperESXI::getArrayMorHost: RetrievePropertiesEx host fail - 12
7/21 8:41:05.663 5070 Facility ???ERROR: WrapperESXI::getVMList: getArrayMorHost is fail - 12
7/21 8:41:05.663 5070 Facility ???ERROR: VMConverter::ESXIConverter::GetVMListInfo: getVMList fail - 12
SOAP SDK paths are also supported.
https://<vCenter-IP-or-FQDN>/sdk/vimService.wsdl
I log in to vCenter using administrator(AT)vsphere.local. So it's probably not a permissions issue.
The V2V machine is on the same subnet and in the same domain.
There are several data centers in vCenter, some with clusters and some without.
It doesn't work with DNS, FQDN, or IP.
I can query VMs from a ESXI-Host using root.
I can't get anything through vCenter.
Thank you very much for any ideas.
Tue Jul 21, 2026 8:11 am
Welcome to StarWind Forum. I've forwarded your request to the dev team.
The most realistic workaround for now seems to be running the conversion through ESXi while we are looking for a solution.
Sorry for any inconvenience.
LHBL2003
Tue Jul 21, 2026 8:56 am
Unfortunately, I can only implement my plan through vCenter. So I'd appreciate it if there were a solution. It might be helpful to know that the SOAP authentication request is also received by vCenter.
Tue Jul 21, 2026 9:04 am
Thanks for your update. I've forwarded this request to the dev team.
LHBL2003
Tue Jul 21, 2026 12:45 pm
I would have liked to give feedback much earlier, but your website's anti-spam rule keeps telling me I have to wait a few minutes. :(
The images and the log are included in the attachment. Unfortunately, there are significant limitations here.
V2V_Diagnose_Attachments.7z
(125.41 KiB) Downloaded 2819 times
I was able to narrow down the problem. V2V does not support folders between the DataCenter and the ESXi-host. However, I need these as a permission level. So V2V would need to support folders in the host view.
I therefore request that the V2V software be updated.
Here's my approach:
I've anonymized the content a bit. I found a log file:
Attachment: V2V_Diagnose_Attachments.7z --> vpxd.log
less /var/log/vmware/vpxd/vpxd.log
And I noticed something with SHIFT-G (for end), SHIFT-F (for follow mode), and CTRL+C (for STOP).
Error Found: There is a property error named “Host”: 2026-07-21T09:10:03.450Z
I checked the supported SOAP versions:
https://vcenter.MyDomain.local/sdk/vimS ... rsions.xml
Attachment: V2V_Diagnose_Attachments.7z --> vimServiceVersion.png
Ich habe die im Protokoll erwähnte Gruppen-ID nachgeschlagen: group-h17016.
https://vcenter.MyDomain.local.local/mo ... oup-h17016
Attachment: V2V_Diagnose_Attachments.7z --> group-h17016.png
As well as the parent group, which is a folder:
https://vcenter.MyDomain.local.local/mo ... oup-h17013
Attachment: V2V_Diagnose_Attachments.7z --> group-h17013.png
Error source identified:
- If I remove the host from the folder and move it to the DataCenter level, the error persists.
- If I delete the empty folder in the DataCenter, the error disappears.
- I then get the error with the next host in the folder of the next DataCenter.
Now all I need is a fix for the V2V software:
Support for folders in the Host view.
LHBL2003
Tue Jul 21, 2026 1:21 pm
It really is because of the folders. I would therefore like to request a product improvement. I removed the folders, and then StarWind V2V scanned the data set.
Tue Jul 21, 2026 1:52 pm
Thanks for sharing!
LHBL2003
Tue Jul 21, 2026 3:05 pm
I hope, though, that this will be forwarded to the development department. Because this is a bug, not a solution. :lol:
Tue Jul 21, 2026 3:17 pm
Yup, they were given this exact thread (you are welcome to leave some kind words for them here :D)
Anyway, thanks for pointing out this limitation.
