Device not found
lam2026
Thu Jul 16, 2026 3:05 am
Hi everyone,
I am a new StarWind VSAN Free user and I am currently learning the ropes with VSAN technology.
I only have a single node right now. I have set up a Windows Server 2025 environment and installed the StarWind VSAN Free Windows application (bare-metal, not using the CVM). I successfully created a standalone device named imagefile1 and added it to a target.
When I list the targets using the enumDevicesTargets.ps1 script, it shows up correctly:
Target:
Alias : vsan1
IsClustered : True
Devices : imagefile1
However, when I try to test other scripts, specifically MaintenanceMode.ps1/ CheckMaintenanceMode.ps1, the CLI returns the following warning:
WARNING: Device {imagefile1} not found
For reference, here are the parameters I am using in the script:
param($addr="127.0.0.1", $port=3261, $user="root", $password="starwind",
	  $deviceName="imagefile1",
	  $enable=$true,
	  $force=$false)
And here is the corresponding device entry from my starwind.cfg:
<device name="imagefile1" header="Headers\img1\img1.swdsk" node="0"/>
Does anyone know why the maintenance script might be failing to find the device, or if I am formatting the $deviceName parameter incorrectly? or if there is no maintance mode to enable because I am a standalone node? Any guidance would be greatly appreciated!
Thanks in advance.
