Need version 8.0.0 build 20089
Brayan08
Mon Jun 29, 2026 4:10 pm
Hi all,
I am trying to deploy the HA device on a proxmox vm. I am trying to do it in the meanwhile with Starwind management console, and it is stating this when I connect to the node thru the mngt console, Console (v8.0.0 build 20089) and Service (v8.0.0 build 15260) build versions do not match. This can cause issues. Please use the same build versions of Console and Service!
Am I able to get supplied with the version 8.0.0 build 20089 as a .run file in order to upgrade my CVM's VM's. Thank you!
Mon Jun 29, 2026 4:28 pm
It will be best to update CVM VMs.
You can leave things as is, but StarWindX module (i.e., powershell scripts might not be working).
Brayan08
Mon Jun 29, 2026 7:45 pm
Yes sir, but I need the .run files to be able to update the CVM VM's.
May someone or yourself, or point me to the right direction, can supply me with that tar file I need?
Screenshot 2026-06-29 154228.png (14.21 KiB) Viewed 16020 times
Mon Jun 29, 2026 7:55 pm
Is it Ubuntu-based CVM or is it an older CentOS7 one?
If you are using a CentOS7-based one, update VSAN using that installer to 20086. Downgrade the console using this installer https://starwind.my.salesforce.com/sfc/ ... 8QjrStarSw (20086).
For Ubuntu-based CVM, you need to go straight to 20089 using the Web UI Update feature (only online updates).
Good luck with your project!
Brayan08
Mon Jun 29, 2026 8:35 pm
I am running StarWind VSA on Linux (Wine-based nodes).
I installed it from the Free HCI appliance, and Proxmox as the hypervisor.
It is Operating System
CentOS Linux 7 (Core), running on Cockpit.
Ok, I'll follow your instructions. Thank you sir!
Tue Jun 30, 2026 7:51 am
Yeah, sadly, you can go only to 20086 with that one. Waiting for the 20089 offline update to be available later.
Brayan08
Tue Jun 30, 2026 6:37 pm
No worries, thank you sir for all your help!
Tue Jun 30, 2026 9:54 pm
Glad to help :)
P.S Debian-based CVM should be coming early autumn, stay tuned.
