HA LUN Status broken in web UI ?
Torx
Thu May 28, 2026 12:56 pm
Hello All,
I'm running VSAN Free with 3 nodes as VMs with proxmox since 4 years. Since upgrade to v8.0.0 Build 20086 I have strange LUN behavior in web ui:
Bildschirmfoto 2026-05-28 um 14.48.16.png (78.73 KiB) Viewed 14649 times
I see such behavior on every node of the cluster - the node of web ui is synchronized and two other are offline and status is unknown. The starwind windows console has no errors - all nodes are visible and synchronized. technically there re no problems too. I also checked management / heartbeat networking - no errors. node restart - no changes.
Is it a web ui bug?
Regards
Sergey
Thu May 28, 2026 2:08 pm
Known issue. Please remove the appliances from the Appliances view and add them back.
Torx
Fri May 29, 2026 12:07 pm
Thanks! It works flawlessly.
Fri May 29, 2026 12:18 pm
Thanks for your feedback!
