AutoSynch Undefined in HA PowerShell Script
Raymond
Sat Nov 15, 2025 11:25 am
Hi everyone,
I followed the sample PowerShell script from the StarWind Virtual SAN Configuration Guide for VMware vSphere
(link available here: https://www.starwindsoftware.com/resour ... shell-cli/ )
to create a HA LUN in my lab environment.
After the LUN was created, I noticed that autoSynch and autoSynch2 were never defined in the sample script.
Both nodes therefore receive:
$Node.AutoSynch = $null
My questions:
1. Does setting AutoSynch = $null effectively disable automatic synchronization?
2. Is the intended value supposed to be $true?
3. Can the AutoSynch setting be changed on an existing HA device, or must the LUN be recreated?
Any clarification or guidance would be greatly appreciated.
Below is my script adapted for my environment:
param($addr="192.168.129.84", $port=3261, $user="root", $password="starwind",
      $addr2="192.168.129.85", $port2=$port, $user2=$user, $password2=$password,
#common
      $initMethod="NotSynchronize",
      $size=1048576,
      $sectorSize=512,
      $failover=0,
      $bmpType=1,
      $bmpStrategy=0,
#primary node
      $imagePath="/mnt/md127",
      $imageName="device1",
      $createImage=$true,
      $storageName="",
      $targetAlias="target1",
      $poolName="pool1",
      $syncSessionCount=1,
      $aluaOptimized=$true,
      $cacheMode="none",
      $cacheSize=0,
      $syncInterface="#p2=192.168.21.11:3260",
      $hbInterface="#p2=192.168.20.11:3260",
      $createTarget=$true,
      $bmpFolderPath="",
#secondary node
      $imagePath2="/mnt/md127",
      $imageName2="device1",
      $createImage2=$true,
      $storageName2="",
      $targetAlias2="target1",
      $poolName2="pool1",
      $syncSessionCount2=1,
      $aluaOptimized2=$false,
      $cacheMode2=$cacheMode,
      $cacheSize2=$cacheSize,
      $syncInterface2="#p1=192.168.21.10:3260",
      $hbInterface2="#p1=192.168.20.10:3260",
      $createTarget2=$true,
      $bmpFolderPath2=""
Import-Module StarWindX
try
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Thanks in advance!
Sat Nov 15, 2025 12:05 pm
Welcome to StarWind Forum!
I think this would be helpful.
viewtopic.php?f=5&t=6852&p=37208&hilit=HINT8#p37208.
If you plan the system for POC or production use, please make sure that it meets system requirements https://www.starwindsoftware.com/system-requirements
Good luck with your project.
