I have a physical machine with server 2012 that I am trying to convert to a Hyper-V 2022 server and I am getting the Access is Denied 0x80070005 error.
Using local administrator credentials for both machines.
On the Hyper-V 2022 target, credssp is enabled.
On the source Physical machine I ran this command: Enable-WSManCredSSP -Role Client -DelegateComputer "target.domain.local"
Ran v2v converter as administrator on source physical machine.
Disabled firewall on both machines.
This is all i get in logs:
11/10 13:24:40.792 f94c Facility ???ERROR: VMConverter::HyperVConverter::Connection: connect fail - 0x80070005
11/10 13:24:41.623 f94c Facility ???WARNING: CPPHYPERVConnectionTo::onNext: connect Access is denied.
(0x80070005)
11/10 13:28:51.414 94c4 Facility ???INFO: WrapperHyperV::connect: Host - \\target\root\virtualization\v2
11/10 13:28:51.434 94c4 Facility ???ERROR: WrapperHyperV::connect: pLoc->ConnectServer \\target\root\virtualization\v2 - 0x80070005
11/10 13:28:51.434 94c4 Facility ???ERROR: WrapperHyperV::failResultToStr: Last Error - Access is denied.
(0x80070005)
11/10 13:28:51.434 94c4 Facility ???ERROR: VMConverter::HyperVConverter::Connection: connect fail - 0x80070005
Halp!
