mete
Fri Oct 24, 2025 6:52 am
$tape = Add-VirtualTape -VTLDevice $device -tapeType $device.DriveType -tapeSize $size -maxDataFileSize $maxDataFileSize
results
Error:
200 Failed: invalid parameter value..
$device is correct and valid, DriveType is 8, $size is 0 and $maxDataFileSize is 0. What is the invalid parameter value ?
mete
Fri Oct 24, 2025 7:53 am
param($addr="127.0.0.1", $port=3261, $user="root", $password="starwind",
$libraryName='vtl',
#[parameter(Mandatory=$true)]$barCode,
$size=0, # tape size in megabytes. If this parameter is equal 0, maximum supported size by specified tape type will be used
$maxDataFileSize=0) # part size in megabytes. Tape data files will be split into parts. If this parameter is equal 0, the tape will not split.
Import-Module StarWindX
try
Enable-SWXLog
$server.Connect()
$device = Get-Device $server -name $libraryName
if( !$device )
throw "library not found"
$device
$tape
#$params = new-object -ComObject StarWindX.Parameters
#if ($barcode)
# $params.AppendParam("barCode", $barCode)
#$tape = $device.CreateTape($device.DriveType, $size, $maxDataFileSize, $params)
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
outputs
.\createTape.ps1
DeviceType : VTL
DeviceId : 0x0000022DAAC57480
File :
TargetName : iqn.2008-08.com.starwindsoftware:vtl-target
TargetId : 0x0000022DAA1D6F80
CacheMode : empty
CacheSize : empty
CacheBlockExpiryPeriod : empty
Exists : True
DeviceLUN : 0
IsSnapshotsSupported : False
Snapshots :
SectorSize :
State : 0
Parent :
Tapes : System.__ComObject
AvailableSlots : 96
TransportSlots : 1
DriveSlots : 4
ImportExportSlots : 3
StorageSlots : 96
Slots : System.__ComObject
ReplicationSettings : System.__ComObject
DriveType : 8
Error:
Fri Oct 24, 2025 11:06 am
Thanks for your update. Please try
1. Custom size.
2. Different Libraryname value (It might be also good to see /headers / or StarWind.cfg)
mete
Fri Oct 24, 2025 1:18 pm
I believe I found the problem, it is because the folder for the tapes (given to Add-VirtualTapeLibrary -path) did not exist.
