esxi to hyper-v - application just closes
meatymcsorley
Sun Jul 13, 2025 2:09 am
yesterday i moved a VM using the hot migration and realised after i hadn't uninststalled vmware tools and it wouldn't boot. it was a tiny VM so i just deleted it and started over. starwind would abruptly close in the middle of converting, i tried several times and saw the same thing happen. Since it was a small vm i just downloaded the vmdk from esx and converted it, no problem.
i loved the idea of a hot migration however so i picked another VM that was 6x the size of the first one, uninstalled VMware tools, and let it rip and went to bed. woke up this morning and it was migrated and converted and sitting in hyper-v and booted perfectly. grabbed another small VM and started a third migration and now i'm seeing the same issue as the first where the application just closes - no error message, etc. logs below:
7/12 17:42:01.611 2958 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/12 17:42:01.611 2958 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.757
7/12 17:42:01.614 2958 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/12 17:42:01.615 2958 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/12 17:42:01.618 2958 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
7/12 17:42:01.621 2958 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 53cd0000
7/12 17:42:01.632 2958 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 53cd0000
7/12 17:42:05.207 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/12 17:42:17.751 b4c Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.1.198/sdk
7/12 17:42:17.787 b4c Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52c9cebc-08b2-a1a8-cc27-0deea63ca1e6
7/12 17:42:17.788 217c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Worker thread started.
7/12 17:42:17.788 b4c Facility ???INFO: VMConverter::ESXIConverter::Connection: No_timeout ESX connection
7/12 17:42:17.788 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/12 17:42:17.892 2958 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
7/12 17:42:23.563 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
7/12 17:42:26.485 2958 Facility ???INFO: CPPSynchronization::onNext: Synchronization for - [
7/12 17:42:26.485 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/12 17:42:28.956 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAzure
7/12 17:42:36.896 32e4 Facility ???INFO: WrapperHyperV::connect: Host - \\SEI-HV01\root\virtualization\v2
7/12 17:42:36.931 32e4 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
7/12 17:42:36.932 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
7/12 17:42:44.471 2958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/12 17:42:44.474 cf0 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
7/12 17:42:44.506 cf0 Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/12 17:42:45.622 cf0 Facility ???INFO: WrapperESXI::Wait: Progress - 100
7/12 17:42:45.889 cf0 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [VMFS02] WinServer/WinServer.vmdk, pathOutput: C:\ClusterStorage\Volume2\HYPER-V\sacrvt\Virtual Hard Disks\WinServe.vhd
7/12 17:42:46.074 cf0 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [VMFS02] WinServer/WinServer.vmdk
7/12 17:42:46.074 cf0 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=133
7/12 17:42:46.085 cf0 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - FF:52:0E:F2:E0:75:0D:3A:1E:75:0B:2F:61:94:28:95:6D:7B:E2:36
7/12 17:42:47.294 cf0 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
7/12 17:42:48.051 cf0 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
7/12 17:47:17.789 217c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Timeout ESX connection. Performing updates.
7/12 17:52:17.789 217c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Timeout ESX connection. Performing updates.
7/12 17:57:17.799 217c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Timeout ESX connection. Performing updates.
7/12 18:02:17.805 217c Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_51a4e26504ac6476d417d538947b592f>::operator (): Timeout ESX connection. Performing updates.
Sun Jul 13, 2025 7:51 am
Try tweaking the timeouts as described here viewtopic.php?f=15&t=6816&p=39004&hilit ... ssh#p39004
DamionLedner
Wed Jan 07, 2026 4:34 am
yaroslav (staff) wrote: ↑
Try tweaking the timeouts as described here viewtopic.php?f=15&t=6816&p=39004&hilit ... sh#p39004/
thank you :D
Wed Jan 07, 2026 8:08 am
You are welcome :)
