Problem create VD HA 2 Nodes
florent
Wed Jul 09, 2025 10:20 am
I have two servers in Microsoft Windows Server 2019 Standard. When i would like create en VD in HA with 2 Nodes in Powershell,
During the VD creation process, PowerShell closes and then reopens. In the Starwind console, the HA Target is created with the VD in yellow. On the second host, it's just the image file in gray.
However, it did create the disk image files.
In the Windows logs, I have the following errors:
Nom de l’application défaillante PowerShell_ISE.exe, version : 10.0.17763.1, horodatage : 0xd129981e
Nom du module défaillant : StarWindX.dll, version : 1.0.0.611, horodatage : 0x647793c3
Code d’exception : 0xc0000005
Décalage d’erreur : 0x00000000000036aa
ID du processus défaillant : 0x894
Heure de début de l’application défaillante : 0x01dbf0b5bd0cc31f
Chemin d’accès de l’application défaillante : C:\Windows\system32\WindowsPowerShell\v1.0\PowerShell_ISE.exe
Chemin d’accès du module défaillant: C:\Program Files\StarWind Software\StarWind\StarWindX\x64\StarWindX.dll
ID de rapport : 72dfe1c0-574f-4f48-ab4a-4ef051f51622
Nom complet du package défaillant :
ID de l’application relative au package défaillant : "
Have you ever encountered this problem ?
Screen Starwind Console.png (5.65 KiB) Viewed 10934 times
Log Windows.png (43.44 KiB) Viewed 10934 times
Wed Jul 09, 2025 2:27 pm
There's something wrong with PowerShell, I believe.
Please check if you have anything security-related that clashes with PowerShell.
