VSAN Hardware Configuration
chipdewolfe
Wed Jul 02, 2025 2:32 pm
I am in the process of specifying hardware for a new all-flash StarWind 3-node VSAN. They would be connected to two SN2700 switches. Would the following be a fully compatible/optimal platform?
SuperMicro 221H-TN24R
2 x Intel Xeon Gold 6442Y
16 x 32GB PC5-38400 4800MHz DDR5 ECC RDIMM (512GB)
2 x 800GB Micron 7450 MAX Series U.3 PCIe 4.0 x4 NVMe Solid State Drive (RAID 1, Boot Drive)
12 x 12.8TB Micron 7450 MAX Series U.3 PCIe 4.0 x4 NVMe Solid State Drive (RAID 10, Data Drive)
Intel VROC Premium
2 x NVIDIA® ConnectX®-6 Dx EN 100-Gigabit Ethernet Adapter - PCIe 4.0 x16 - 2x QSFP56
Supermicro AIOM OCP 3.0 - 2x 10GbE RJ45 - Intel X550-AT2 - PCI-E 3.0 x4 - AOC-ATG-i2TM
Supermicro AOM-TPM-9670V - Trusted Platform Module - TPM 2.0 - X11 X12 - Not Provisioned - Vertical
Supermicro Update Manager (SUM) (OOB Management Package), included
Supermicro Server Manager (SSM) (DataCenter Management Package)
Thanks for any insights!
Wed Jul 02, 2025 2:52 pm
Thanks for sharing. The spec looks ok, yet we don't approve specs for the software users.
VSAN is hardware agnostic (see the system requirements here https://www.starwindsoftware.com/system-requirements). Also, it is always better to use RAID controller and direct connections for DATA and SYNC.
coaloremindle
Mon Jul 14, 2025 4:31 am
A key adjustment to the optimal StarWind VSAN deployment is to disable or remove any RAID functionality (including VROC) for the 12 12.8TB NVMe data drives, presenting them as raw disks directly to the operating system. This allows StarWind VSAN to manage the storage stack natively and efficiently, leveraging internal replication to protect data across all three nodes. Configure dedicated 100GbE paths for VSAN synchronization and logically segment other traffic.
Mon Jul 14, 2025 4:55 am
Welcome to StarWind Forum. Two notes:
-vROC is not supported.
-100 GBE is not a must.
