hba_rescan.ps1 trigger
aeon
Tue Jul 01, 2025 10:05 am
Hi. i can not find a document that specifiy this script will work how frequently run.
Did i have to cron this myself?
Tue Jul 01, 2025 10:29 am
Rescan is event-triggered, not time-triggered. There's a logwatcher file (not a *.ps1). Check it out.
We do not expect our users to alter it, though, unless there is any strong need for it.
aeon
Wed Jul 02, 2025 7:17 am
ok.in two node vsan due to power loss or network problems sometimes surviving nodes cant lose connection to power off ed node or when node came back doesn t resume iscsi connection unsless manuelly rescan hba from esx or run this script manually.
i waited so long time to this script run itself but it doesnt.
which event it will run . can you specifiy.
i have seen id's in logwatcher but this event doesnt work for me.
if i schedule by minute is it get too disruptive to esx
EVENT1="ID_257"
EVENT2="ID_773"
EVENT3="ID_782"
EVENT4="ID_788"
EVENT5="ID_817"
Wed Jul 02, 2025 7:25 am
Check this out https://www.starwindsoftware.com/help/E ... dVSAN.html.
You can add "partner became not synchronized", "device became not synchronized", "partner became synchronized"
aeon
Wed Jul 02, 2025 7:40 am
last question :)
no rescan even restart of cvm.
log watcher responsible for running hba_rescan.py and i did not filled with user pass
i did for hba_rescan.ps1. which process is responsible for that?
Screenshot 2025-07-02 103755.png (39.17 KiB) Viewed 14085 times
Wed Jul 02, 2025 7:48 am
You need to add details to hba_rescan_conf.py. It feeds the credentials into hba_rescan.py.
I've just realized that events are also somewhat built into the script itself, so add them there as well.
