VSAN Free on Proxmox Virtual Appliance
ticktok
Tue Jul 01, 2025 4:55 am
I have set up a Starwind VM on each host. This is a 2 node set up with a third Ubuntu VM providing a quorum.Each host has 2 * 2Tb Samsung NVMe drives that I have used as passthrough devices to the Starwind VMs as the basis for shared storage. Each host has 2 10Gb nics with 2 ports each allowing me to create 4 Linux Bridges.
One is for management, one for data and one for replication. This leaves one spare and I am not sure whether to make use it for data or replication?
Does it matter??
Tue Jul 01, 2025 6:48 am
StarWind VSAN does not team or add up the bandwidth of the NICs dedicated to DATA or Replication. An extra NIC will serve only for redundancy.
While it does not really matter, I'd suggest adding it for replication.
p.s. consider joining NVMe-oF beta :)
ticktok
Tue Jul 01, 2025 7:08 am
Thanks for the advice, it's exactly what I chose, since there are only two servers the replication links are crossover cables between the two servers, eliminating the possibility of a switch failure or update.
Tue Jul 01, 2025 7:15 am
Using DAC for data and SYNC is our most preferred design.
If you do like the idea of joining beta, reach out to us here https://www.starwindsoftware.com/support-form
ticktok
Tue Jul 01, 2025 7:39 am
I haven't got sufficient storage at the moment to consider joining NVMe-oF beta and I'm not sure my customers would appreciate their data being on a beta program.
I'll investigate my options for adding more NVMe storage to the nodes and if I can, then I'll consider applying. The resource library was very helpful in getting to a working solution.
p.s. my career started in the late 1970's writing assembler for tiny little SCADA components, with horrible memory arrangements and I had to write my own interrupt driven micro OS.
Tue Jul 01, 2025 8:14 am
Beta is only for labs. I guess that's why it is beta still :D
You are always welcome. From what I see in a different thread, you have a perpetual key. If you have an active support contract, let us open a support ticket.
