nd_rperf.exe not working with Intel E810 NIC: ND_INVALID_ADDRESS
manigandanj
Wed Jun 25, 2025 4:33 am
Hi all,
I’m trying to test RDMA connectivity and performance using the nd_rperf.exe tool on Server 2022 with an Intel E810 NIC. However, I’m encountering the following error when running the tool (getting this in both server and client mode)
nd_rperf.exe -s -a 192.168.155.212
StarWind RDMA performance and latency test tool v1.0.2
NdOpenIAdapter failed with c0000141 - ND_INVALID_ADDRESS
  • The IP address I’m using (192.168.155.212) is assigned to the RDMA-capable Intel E810 adapter.
  • I have the latest Intel drivers and firmware installed.
  • RDMA is enabled and appears functional otherwise (I can see RDMA stats with other tools).
Has anyone successfully used nd_rperf.exe with Intel E810 NICs? Does this tool require Mellanox or RoCE interfaces, or is there a known compatibility issue with Intel iWARP?
Would appreciate any troubleshooting tips or confirmation of support/limitations.
Wed Jun 25, 2025 10:55 am
I believe it needs RoCE.
larkorganize
Tue Jul 01, 2025 2:55 am
If you need to test Intel E810 RDMA, consider using Intel's own utilities or generic Network Direct benchmarking tools like `nd_bench.exe`.
