starwinds v2v converter anyone
HansHoppe
Wed May 28, 2025 1:44 am
I have a esxi 5.5 server with one DC on it. I want to migrate the one vm (DC) to a newer esxi host (esxi 7.0 update 2).
Is this a viable optiontunnel rush.
Is the software truly free?
Once the conversion is done the old server will still have the VM and the new server will have it as well correct? It doesn't delete from the old server right. Looking for a blackout plan just incase something goes wrong.
Thanks in advance.
Wed May 28, 2025 4:08 am
The software is free and should work with ESXi 5.5.
It does not remove the source VM, so you are welcome just to try it.
