Is it ok to run yum or windows updates on VSAN installs?
Wifear
Fri May 23, 2025 8:44 am
Is it ok to run yum or windows updates on VSAN installs? For some reason I thought you should not run yum update but only use the starwind update script but I have found that it only updates starwind and not the OS.
Fri May 23, 2025 9:04 am
Windows updates are OK. yum is not quite ok (better not to do that) because /boot can be filled.
Sophia2005
Wed Jun 04, 2025 3:52 am
You can run 'yum update,' but do so with caution. The StarWind script only updates VSAN, not the OS. Always test updates first if possible, especially kernel or network-related ones, and update one node at a time in clusters. For Windows, the same rule — manual updates with planned reboots.
Wed Jun 04, 2025 7:05 am
You SHOULD NOT run yum update because /boot can be filled. Use the updater.
For CentOS7 CVM, go for offline update procedure.
