Lex
Wed Apr 30, 2025 1:39 am
I have presented 10 LUNs from storage to my Windows 2019 initiator over RoCEv2, and while each connection is successful, it only sees 8 of the 10 volumes presented to the host from the array. Is this a Starwind Initiator limitation? Any settings I am overlooking which would unlock more volumes?
Wed Apr 30, 2025 8:21 am
On the initiator host, go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e97b-e325-11ce-bfc1-08002be10318}
expand something that "can be expanded" e.g., 0004 directory. Check MaxNamespaces value (set to something between 1 and 255).
Reboot, and try over again.
Lex
Wed Apr 30, 2025 5:22 pm
Thank you for this guidance, but I don't see MaxNamespaces in the location you specified. If this is something I can create, please let me know if it goes in the root of the 000# folder and the value type (dword, etc)
- MaxNamespaces-Registry.jpg (195.34 KiB) Viewed 101587 times
Lex on Wed Apr 30, 2025 5:30 pm, edited 1 time in total.
Lex
Wed Apr 30, 2025 6:30 pm
Okay, I have done as suggested and the system comes up with the same 8 drives. Please see the attachment and let me know if this is correct.
Must I disconnect all paths and reconnect in order to see the change?
- MaxNamespaces-update.jpg (192.76 KiB) Viewed 101571 times
Lex
Wed Apr 30, 2025 7:26 pm
Nope, confirmed that disconnecting all and reconnecting (following registry change + reboot) has no effect on LUNs connected. Still limited to 8.
StarNVMeoF Controller Application v 2.0.0.672
Our Miniport #2 (ver 2.0 build 672)
HostId 7958DA786AF086D7-A86FE9ADF955F16E, HostName a09-23
NET_LUID: 0x600800B000000
Connecting to RDMA target at addr 10.3.14.51:4420 from 10.3.14.11 SubNQN=nqn.2010-06.com.purestorage:flasharray.561d839ad7a29cc8 HostNQN=nqn.2008-08.com.starwindsoftware.a09-23 nq=0 qd=0 node=0 core=0...
Controller connected: TargetId = [0]
numLuns = 8, numIoQs = 96, ioQDepth = 128, numaNode = 0, firstCore = 0
Adding persistent entry for target 0...
Persistent entry for target 0 added
Wed Apr 30, 2025 8:50 pm
Check also here.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\StarNVMeoF\Parameters (the older place for the registry)
Please try disconnecting all the paths and reconnect too.
Lex
Wed Apr 30, 2025 11:51 pm
The value was not in that location either, but I added it, rebooted, disconnected all paths and reconnected. Unfortunately, there is no change...still 8 LUNs connected out of 10.
Lex
Fri May 02, 2025 12:35 am
Alright, THAT did the trick. I now see the 10 LUNs provisioned to the host.
If possible, in future releases, it would be great have this be either dynamic or at least set to a logical limit in line with the underlying operating system. Windows supports 26 lettered volumes by default, with 2 typically in use by default, so a number like 24 is probably a good default with enough headroom so more users don't hit what I hit.
Two questions:
1) You said set MaxNamespaces to something between 1 and 255. Does the number truly not matter or have any correlation to the number of LUNs i want to support >8?
2) Does setting this value utilize more memory or CPU or any other consequence that would be reason not to set it?
Thank you for your quick replies and help.
Fri May 02, 2025 1:31 am
You are welcome. Sorry for missing the spot for the first two times
This parameter requires the system to lock more resources to the initiator to be ready to serve more connections. That's why we picked the minimum value. I don't think the cap of 24 LUNs per target will break anything (we set it to a higher value several times), so you are good.
For the newest releases, this parameter can be tweaked in UI if UI is available according to the license.
