Veeam+VTL(trial)
sean1
Sun Mar 02, 2025 11:43 am
I have installed and tested a Veeam file copy and a backup from an MS server to the VTL(tests have proven to work, according to Veeam). What logs do I look at to tell me the cloud copy is working? I do not see any data there. Tested with 2 different Oracle buckets(standard and glacier/archive bucket). Connectivity to the buckets is seen in the logs. What tells me that things are working or not? The Technical documents and video do not go down to debug level so it is not helping when I cannot see why the data is not flowing to the buckets.
Sun Mar 02, 2025 12:53 pm
There should be data transfer logs (upload speeds).
P.S. if you are trialing the solution, you can reach out to the person who provided you with the key and download link for technical questions.
sean1
Mon Mar 03, 2025 9:16 am
I have successfully backed up files to the Oracle archive/glacier bucket via Veeam files to tape job.
I want to retrieve/restore the data.
Still, Veeam is showing the tape offline
(Starwinds VTL showing a blank tape)
and Veeam cannot proceed with the restore(tape offline) and checking the VTL, the tape is not in the slot.
The cloud tape is not visible (even when attempting to restore from cloud-"S3")The tape is not visible in the cloud restore window.
Which begs the question,does Starwind support glacier buckets or just standard for backup and recovery?
I am using the S3 Browser now to move the 3 files(tape no.1) out of glacier to prove my point.
Mon Mar 03, 2025 9:25 am
Are you using Veeam to offload to the cloud? If the tape is visible in Veeam, that's purely the question of Veeam configuration from that point.
StarWind Features Cloud Replicator (https://www.starwindsoftware.com/help/C ... cator.html) that allows offloading tapes to the cloud using the StarWind VTL wizard/config files.
If you are trialing the solution the best will be to reach out to the person who provided you with the key for technical inquiries.
