Can't convert and upload vmdk file to Proxmox VE server
Udohhh
Wed Feb 26, 2025 1:33 pm
I have a Linux VM in a VMDK file which I'm trying to upload to a freshly installed Proxmox VE 8.3 server.
I made sure that the vmdk file has no spaces nor non-English characters.
I also tested with and without Defender Firewall on.
After starting the conversion, it immediately says "Conversion cancelled".
This is the log:
2/26 10:10:48.741 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Connect to Proxmox host
2/26 10:10:48.874 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetHostVersion: Get proxmox host version info
2/26 10:10:48.897 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::BuildVM: Get virtual machines lists
2/26 10:10:48.897 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetStorageContent: Get storage info lists
2/26 10:10:49.028 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetDiskPath: Get storage info lists
2/26 10:10:49.097 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetStorageContent: Get storage info lists
2/26 10:10:49.113 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetDiskInfo: Get disk information
2/26 10:10:49.144 56ac Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Successfully connected to proxmox host
2/26 10:10:49.144 2840 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
2/26 10:11:11.518 2840 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
2/26 10:11:11.533 1328 Facility ???INFO: CPPConverting::Convert: InConvertType: 4, OutConvertType: 15
2/26 10:11:11.533 2334 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: CreateVM
2/26 10:11:11.533 2334 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Set disks
2/26 10:11:11.533 2334 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: disk name ide0, local:1.000000,format=raw
2/26 10:11:11.533 2334 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Sending request
2/26 10:11:11.566 2334 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Responce is received
2/26 10:11:11.566 2334 Facility ???ERROR: Proxmox::WrapperProxmox::WrapperProxmoxImpl::CreateVM: Can not create virtual machine: 400
2/26 10:11:11.566 1328 Facility ???WARNING: CPPConverting::Convert: CANCEL
Any suggestion on what I can do?
Udohhh
Wed Feb 26, 2025 1:35 pm
I'm using V2V Converter version 9.0.1.623
Running on Windows 10
Wed Feb 26, 2025 2:00 pm
Make sure your Proxmox user has enough privileges and try a different Proxmox host if you have a cluster.
You can copy that VMDK straight to Proxmox and create the VM there.
As an alternative, convert the disk alone.
ScooterSG1
Tue Apr 15, 2025 3:26 pm
Having the same issue. The Proxmox user we are using is root, so I don't think there is an account with more permissions!
Tue Apr 15, 2025 3:32 pm
I think the best will be if you stick with one thread.
