Goodday
While performing a Spectrum Protect dbs backup to VTL we get the following error:
18-02-2025 10:08:09 ANR2017I Administrator ADMIN1 issued command: BACKUP DB
devc=vtl t=dbs (SESSION: 170958)
18-02-2025 10:08:10 ANR0984I Process 3698 for Database Backup started in the
BACKGROUND at 10:08:10. (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR4559I Backup DB is in progress. (SESSION: 170958,
PROCESS: 3698)
18-02-2025 10:08:10 ANR2287I Snapshot database backup started as process
3698. (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR8530W Volume VTL0003I in drive VTL_DRIVE1 in library
VTLLIB is not labeled. (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR8810I Volume VTL0003I has been labeled in library
VTLLIB. (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR8337I LTO volume VTL0003I mounted in drive VTL_DRIVE1
(mt0.1.0.5). (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR0513I Process 3698 opened output volume VTL0003I.
18-02-2025 10:08:10 ANR1360I Output volume VTL0003I opened (sequence number
1). (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:08:10 ANR4626I Database backup will use 1 streams for
processing with the number originally requested 1.
18-02-2025 10:10:32 ANR1361I Output volume VTL0003I closed. (SESSION: 170961)
18-02-2025 10:10:32 ANR0514I Session 170961 closed volume VTL0003I. (SESSION:
170961)
18-02-2025 10:10:32 ANR4574E Database backup/restore terminated - data
transfer interrupted. (SESSION: 170961)
18-02-2025 10:10:32 ANR0403I Session 170961 ended for node $$_TSMDBMGR_$$
(DB2/NT64). (SESSION: 170961)
18-02-2025 10:10:32 ANR8336I Verifying label of LTO volume VTL0003I in drive
VTL_DRIVE1 (mt0.1.0.5). (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:10:33 ANR8468I LTO volume VTL0003I dismounted from drive
VTL_DRIVE1 (mt0.1.0.5) in library VTLLIB. (SESSION:
18-02-2025 10:10:37 ANR8592I Session 170967 connection is using protocol
TLSV12, cipher specification
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, certificate TSM
Self-Signed Certificate. (SESSION: 170967)
18-02-2025 10:10:37 ANR0406I Session 170967 started for node $$_TSMDBMGR_$$
(DB2/NT64) (SSL RTTSM05.HDE.INTRA[127.0.0.1]:65095).
(SESSION: 170967)
18-02-2025 10:10:37 ANR0403I Session 170967 ended for node $$_TSMDBMGR_$$
(DB2/NT64). (SESSION: 170967)
18-02-2025 10:10:38 ANR2968E Database backup terminated. DB2 sqlcode: -2033.
DB2 sqlerrmc: -50 . (SESSION: 170958, PROCESS:
3698)
18-02-2025 10:10:38 ANR0985I Process 3698 for Database Backup running in the
BACKGROUND completed with completion state FAILURE at
10:10:38. (SESSION: 170958, PROCESS: 3698)
18-02-2025 10:10:38 ANR1893E Process 3698 for Database Backup completed with
a completion state of FAILURE. (SESSION: 170958,
PROCESS: 3698)
It was running:
Protect: TSMPROD1>backup db devc=vtl t=dbs
ANR2287I Snapshot database backup started as process 3698.
ANS8003I Process number 3698 started.
Protect: TSMPROD1>q mo
ANR8330I LTO volume VTL0003I is mounted R/W in drive VTL_DRIVE1 (mt0.1.0.5), status: IN USE.
ANR8334I 1 matches found.
q libv
VTLLIB VTL0003I Private TSMPROD1 DbBackup 1.020
Protect: TSMPROD1>q proc
Process Process Description Process Status
Number
3.698 Database Backup TYPE=SNAPSHOT in progress. Bytes backed up:
11.699 MB. Current output volume(s): VTL0003I.
What could be the reason. It went fine up until 7 days ago.
Regards
Michel.
