LUN Capacity
adminr
Mon Feb 10, 2025 7:37 am
Could you please clarify a moment with LUN size.
I have extended storage and volume for two CVM nodes.
Now the system shows 2.99TB but LUN have become 5.78TB How it could be possible ?
Physical disks are 3TB also.
adminr
Mon Feb 10, 2025 8:54 am
I found out the problem. PowerShell script doesn`t care how many free disk space I have.
it just increase size after running ExtendDevice.ps1 for any size what you set.
IMHO this is incorrect behavior.
Mon Feb 10, 2025 10:17 am
Please share the logs from your system (Log in to the Web management interface -> Select the gear-shaped button -> Expand the VM name view -> Support Bundle) and share the the time stamp.
adminr
Mon Feb 10, 2025 11:13 am
Before each timestamp of my forum posts. Somewhere like that. not sure exactly.
Mon Feb 10, 2025 10:37 am
Mon Feb 10, 2025 11:54 am
Mon Feb 10, 2025 12:36 pm
Got it,
Thanks for your logs. You can delete the link now.
Wed Feb 19, 2025 2:37 pm
The fix will be in the future builds. Please recreate the device with the correct capacity.
