P2V Win7 to VM file
Stapeium
Sun Jan 05, 2025 9:35 pm
Sorry if this is a basic question or Im missing something obvious. Im pretty new to virtualization.
Is there a way to convert a physical windows 7 machine to a VM file that I can run under either vmware workstation or hyperV on a windows Pro host?
Ive tried running the v2v migrator but I dont see the option of saving the VM to a file under any of the VM formats.
What am I missing?
Mon Jan 06, 2025 9:27 am
Welcome to StarWind Forum!
You cannot convert the VM to a file with a StarWind V2V converter. As a workaround, you can try converting each disk to a VMDK. Then, you can resemble the system as a VM.
