Access to *.img after trial license expired
mgdn
Thu Dec 26, 2024 11:21 am
Hello! I have a problem. I really need to get the VM disks from the img storage. But I can't access it. I can't mount the iSCSI either because it won't let me activate the new trial or free license. Please help me, what should I do?
Thu Dec 26, 2024 11:28 am
Welcome to StarWind Forum. Sorry to read that. Please consider reinstalling the OS, mount the *.img, and extract the files.
You can also try reaching out to the person who sent you the key and see what your account manager can do about it.
mgdn
Thu Dec 26, 2024 3:03 pm
Sorry, the option of reinstalling the system to get to the desired VM disk is a very bad option.
I have been suffering for 8 hours already.
Thu Dec 26, 2024 3:24 pm
Stop StarWind VSAN Service -> Mount the *.img file to the system -> override disk reservations (if there are any) as described here https://learn.microsoft.com/en-us/power ... ver2025-ps. -> Get your data
mgdn
Thu Dec 26, 2024 3:26 pm
I can't mount it, it says the image is corrupted.
I'm using Win10 Pro
mgdn
Thu Dec 26, 2024 3:27 pm
<?xml version="1.0" encoding="UTF-8"?>
<header signature="StarWind" version="1.2" path_backup="My Computer\G\backup\Storage1\Storage1.swdsk.bak">
  <device active="true" plugin="imagefile" name="imagefile">
    <storages>
      <storage id="1" type="device" name="imagefile" lun="0x0">
        <interval size="20" units="TB"/>
        <inquiry>
          <serial_id>A41787E0EBDDE768</serial_id>
          <vendor id="STARWIND"/>
          <product id="STARWIND        " revision="0001"/>
          <eui_64>A41787E0EBDDE768</eui_64>
        </inquiry>
        <geometry>
          <sector size="512" psize="4096"/>
          <track sectors="16"/>
          <cylinder tracks="32" count="65535"/>
        </geometry>
      </storage>
    </storages>
  </device>
  <system>
    <resources>
      <storages>
        <storage id="1" name="My Computer\G\backup\Storage1\Storage1.img" type="file">
        </storage>
      </storages>
      <network/>
    </resources>
  </system>
  <node id="1" name="imagefile" shut="false" active="true">
    <storages>
      <storage_ref id="1"/>
    </storages>
    <parameters>
      <asyncmode>yes</asyncmode>
    </parameters>
  </node>
</header>
Thu Dec 26, 2024 3:50 pm
Windows 10 is not a supported OS (see more at https://www.starwindsoftware.com/system-requirements). Transition from the trial key is not generally done. Trial key is not intended for production.
The best way out of it will be: to redeploy the OS or reach out to us at https://www.starwindsoftware.com/support-form.
