Add-HAPartner 3rd Node Srv Exception The server threw an exception 0x80010105
GiveitAGo
Wed Dec 18, 2024 5:59 am
Hi All,
I have Starwind operating "CSV-Witness" and "CSV-Disk01" between two nodes.
Its working great.
I have tried to use Add-HAPartner.ps1 to add a third node and get powershell error:
The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
I'd really appreciate any tips or help with where i'm going wrong.
Node 1 + Node 2 are doing other duties. So my 3x node starwind cluster are Node 3,4,5
I have followed Starwinds best practice and
  • SYNC: each node has 2x 25gb (mellanox-x4) ports direct cable connected to the other two nodes
  • SYNC: node 3: 172.16.20.3 <--> node 4: 172.16.20.4
  • SYNC: node 4: 172.16.21.4 <--> node 5: 172.16.21.5
  • SYNC: node 5: 172.16.22.5 <--> node 3: 172.16.22.3
  • ISCSI: each node has 2x 25gb (mellanox-x4) ports connected to SWITCH1, SWITCH2
  • ISCSI: node 3: 172.16.30.3, 172.16.40.3
  • ISCSI: node 4: 172.16.30.4, 172.16.40.4
  • ISCSI: node 5: 172.16.30.5, 172.16.40.5
  • HB: each node has 2x mgmt interfaces which HB is on
  • HB: node 3: 192.168.1.93, 192.168.1.193
  • HB: node 4: 192.168.1.94, 192.168.1.194
  • HB: node 5: 192.168.1.95, 192.168.1.195
All nodes running latest v8 15554
#Get-Help Add-HAPartner -full
#Get-Help Add-HADevice
#Get-Help about_node
param($addr="192.168.1.93", $port=3261, $user="x", $password="x", $deviceName="HAImage4",
	$addr2="192.168.1.95", $port2=$port, $user2=$user, $password2=$password,
#secondary node
	$imagePath2="My computer\S\starwindVHDs",
	$imageName2="CSV-Disk01",
	$createImage2=$true,
	$targetAlias2="csv-disk01", #lowercase
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$syncInterface2="#p2=172.16.20.4:3260,172.16.21.4:3260;#p3=172.16.21.5:3260,172.16.22.5:3260",# -f $addr,
    $hbInterface2="#p2=192.168.1.194:3260,192.168.1.94:3260;#p3=192.168.1.195:3260,192.168.1.95:3260",
	#$bmpType=1,
	#$bmpStrategy=0,
	#$bmpFolderPath="",
    $selfSyncInterface="#p1=172.16.20.3:3260,172.16.22.3:3260;#p2=172.16.20.4:3260,172.16.21.4:3260",# -f $addr2,
    $selfHbInterface="#p1=192.168.1.193:3260,192.168.1.93:3260;#p2=192.168.1.194,192.168.1.94:3260"
Import-Module StarWindX
try {
    Enable-SWXLog
    $server = New-SWServer $addr $port $user $password
    $server.Connect()
	if( !$device ){
		Write-Host "Device not found" -foreground red
		return
    $node = new-Object Node
    $node.HostName = $addr2
    $node.HostPort = $port2
    $node.Login = $user2
    $node.Password = $password2
    $node.ImagePath = $imagePath2
    $node.ImageName = $imageName2
    $node.CreateImage = $createImage2
    $node.TargetAlias = $targetAlias2
    $node.SyncInterface = $syncInterface2
    $node.HBInterface = $hbInterface2
	$node.AutoSynch = $autoSynch2
	$node.SyncSessionCount = $syncSessionCount2
	$node.ALUAOptimized = $aluaOptimized2
	$node.PoolName = $poolName2
	#$node.BitmapStoreType = $bmpType
	#$node.BitmapStrategy = $bmpStrategy
	#$node.BitmapFolderPath = $bmpFolderPath
    Add-HAPartner $device $node $selfSyncInterface $selfHbInterface #$selfBmpFolderPath
} catch {
	Write-Host $_ -foreground red
} finally {
	$server.Disconnect()
Wed Dec 18, 2024 7:52 am
Try restarting the servers and try again. https://knowledgebase.starwindsoftware. ... installed/ see the restart procedure.
