The object invoked has disconnected from its clients.
KoflDev
Fri Dec 13, 2024 1:10 pm
we try to convert ESX 6.x machines to Hyper-V 2024. But all of them error out with:
12/13 13:19:37.282 aac Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
12/13 13:23:43.655 3f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
12/13 13:43:43.661 3f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
12/13 14:03:43.673 3f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
12/13 14:06:51.931 aac Facility ???INFO: CPPConverting::ConvertImage: Success
12/13 14:06:56.749 aac Facility ???ERROR: WrapperHyperV::getMethod: m_pSvc->GetObjectW Msvm_VirtualSystemManagementService - 0x80010108
12/13 14:06:56.749 aac Facility ???ERROR: WrapperHyperV::failResultToStr: Last Error - The object invoked has disconnected from its clients.
(0x80010108)
12/13 14:06:56.749 aac Facility ???ERROR: WrapperHyperV::create_virtual_machine: getMethod - 0x80010108
12/13 14:06:56.749 aac Facility ???ERROR: VMConverter::HyperVConverter::CreateVM: create_virtual_machine fail - 0x80010108
12/13 14:06:56.749 aac Facility ???ERROR: CPPConverting::ConverterVMtoVM: Create VM - The object invoked has disconnected from its clients.
Thanks for any advice
Fri Dec 13, 2024 2:18 pm
It looks like the firewall or AV on the host where StarWind V2V runs is getting in your way.
Check this out https://forums.starwindsoftware.com/vie ... php?t=6794.
