lukrze
Thu Dec 12, 2024 3:28 pm
Dear friends,
I have multivirtual environment with ovirt, proxmox, esxi.
While esxi and proxmox connections sets up with no issues, the v2v with ovirt connection always gets a "The host name or credentials are wrong".
I'm trying to connect with user credentials "admin@internal" and "kvm.local/ovirt-engine/sso/" and I also tried with other variations and paths but nothing is working for now.
Any help is appreciated
bobstayshaky
Fri Dec 13, 2024 9:51 am
You are using admin@internal as your username, which is standard for oVirt. Ensure that this account is legitimate and has the necessary rights to access the oVirt engine via the API. The kvm.local/ovirt-engine/sso/ portion appears to hint that you are attempting to use SSO (Single Sign-On) authentication. Check that your migration tool uses and supports the correct authentication mechanism.
lukrze
Fri Dec 13, 2024 2:13 pm
I disabled antivirus software and firewall, and nothing has changed, the issue still occurs.
I can login with that account 'admin' via www and with other third party backup software but I cant login via v2v starwind conventer.
In my opinion that 'admin' account seems to have all necessery priveleges.
I use ovirt 4.5.5 nad v2v converter 9.0.1.509
lukrze
Fri Dec 13, 2024 4:25 pm
User admin@ovirt@internal connecting from '192.168.16.230' failed to log in : 'Unable to log in. Verify your login information or contact the system administrator.'.
Sat Dec 14, 2024 4:07 am
Could you please confirm that you restarted the machine you used to run the V2V converter? I noticed that disabling AV might sometimes require a restart.
Also, please try updating V2V to the latest build.
If that still does not work, please pull the new set of logs.
Have a nice weekend!
lukrze
Tue Dec 17, 2024 12:23 pm
I confirm, I restarted machine after disabling av soft, I have latest v2v converter
he log file name: 'logs\V2V_Log-20241217-132045.log' (PID 17296)
Delete log file 'logs\V2V_Log-20241202-174222.log'.
12/17 13:20:45.414 33b8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/17 13:20:45.414 33b8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
12/17 13:20:45.420 33b8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/17 13:20:45.420 33b8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/17 13:20:45.423 33b8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19045
12/17 13:20:45.424 33b8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 73360000
12/17 13:20:45.425 33b8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 73360000
12/17 13:20:50.493 33b8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
12/17 13:21:42.318 33b8 Facility ???INFO: WrapperKVM::KVMWrapper::KVMWrapperImpl::Connect: Connect to the oVirt host
12/17 13:21:42.354 33b8 Facility ???ERROR: WrapperKVM::KVMWrapper::KVMWrapperImpl::Connect: HTTP response status code: 400
