vSAN Free or Trial license does not provide raw LUN
anhdzung88
Wed Nov 27, 2024 6:52 am
When applying Free or Trial license, I cannot create raw LUN target, default is NVMe-oF and cannot change. So that my iSCSI Initiator cannot see the target. How to fix or work around this issue?
Wed Nov 27, 2024 10:52 am
Welcome to StarWind Forum! NVMe-oF is not yet available so the RAW LUN. Please consider using a Simple layout.
P.S. You can reach out to the person who shared the trial key with you for technical assistance.
anhdzung88
Thu Nov 28, 2024 11:00 am
Hi yaroslav, when choosing LUN protocol (as below depiction) on CVM web UI, I can only choose NVMe-oF instead of iSCSI. While hovering on iSCSI item, it says that my license does not support (Free/Trial).
Thu Nov 28, 2024 11:30 am
I am afraid there is some confusion here.
You have iSCSI selected. For free version, you need to use scripts. For Trial, you can continue with GUI.
anhdzung88
Thu Nov 28, 2024 12:05 pm
The image I sent is for illustration purposes only and not the actual image. What I mean is that when selecting the LUN protocol, it defaults to NVMe-oF instead of iSCSI as expected (opposite to the image).
Thu Nov 28, 2024 12:29 pm
Can you please share the screenshot?
anhdzung88
Thu Nov 28, 2024 1:29 pm
Please find attachment.
Thu Nov 28, 2024 4:00 pm
Can you please share the version of the StarWind VSAN VM?
Also, is it a FREE or TRIAL license?
anhdzung88
Fri Nov 29, 2024 4:12 am
The latest version (8.4).
I have tried both Free and Trial license, the same result as capture.
Fri Nov 29, 2024 9:13 am
Can I see the screenshot with the version, please?
NVMe-oF transport is not yet available in the current build. So is the RAW volume. It should not be possible to unlock NVMe-oF transport without RAW volume.
anhdzung88
Mon Dec 02, 2024 1:49 am
Yes, I have created a RAW volume, then NVMe-oF LUN with Free (or Trial) license.
You can download the latest version from your website to recreate the case.
Mon Dec 02, 2024 5:16 am
Since August, I deployed StarWind VSAN in multiple systems. None of them had RAW volume available.
Furthermore, NVMe-oF transport is not available in the latest release build.
dmytro (staff)
Mon Dec 02, 2024 9:04 am
Hello anhdzung88,
Please create a Standard volume to create and utilize iSCSI devices connected to your client host machines via iSCSI Initiator.
For iSCSI LUNs a Standard volume is used while a Raw volume is required for creating NVMe-oF LUNs.
Cheers,
Product Manager, StarWind Virtual SAN
anhdzung88
Mon Dec 02, 2024 9:20 am
But I need Raw volume via iSCSI LUN (for VMFS datastores).
Standard Volume as I understand is an XFS file system, right? And it cannot be used to make datastores (VMFS).
dmytro (staff)
Mon Dec 02, 2024 9:55 am
Hi anhdzung88,
Please check the VSAN configuration guide - https://www.starwindsoftware.com/resour ... ng-web-ui/
iSCSI LUNs utilize the Standard volume only. Indeed it is the XFS file system under the hood. This is the only option to be made to expose the iSCSI device as a VMware VMFS datastore.
Cheers,
