viewing status of v2v
swPete
Wed Nov 13, 2024 4:18 am
Need to do a conversion from ESXi to Hyper-V core of a few Windows servers.
Doing some trial runs.
How do I view a more detailed status of the progress of the conversion?
I don't see the target vhdx file getting any bigger, I don't see anything in the log in the program files directory.
The percent keeps increasing on the progress status, but would like to something a little more solid to track progress.
Going from a ESXi Server to Hyper V with the converter running on the Hyper V machine itself.
Thanks.
Next test will be to copy the files I want to convert local first and then convert.
swPete
Wed Nov 13, 2024 4:25 am
also is there a temp directory being used I can monitor/optimize? I have a bunch of disks to convert so optimizing any temp areas would be benefitial.
Wed Nov 13, 2024 8:07 am
Welcome to StarWind Forum. There is a progress bar when converting via GUI. Are you doing P2V or V2V?
What exactly would you get logged?
Could you please expand on it?
Thanks for your input!
swPete
Wed Nov 13, 2024 5:45 pm
I see the progress bar it just took a very long time to actually make any progress past 4%, eventually I saw the converted virtual disk start increasing in size, which I suppose is good enough along with the status bar.
Thanks.
Wed Nov 13, 2024 6:05 pm
Thanks for your udpate.
swPete
Wed Nov 27, 2024 2:10 am
and afa the progress bar.. it goes from 0-100% then goes back to 0 again.
Wed Nov 27, 2024 8:19 am
Greetings,
For live vm conversion, conversion includes 2 processes: create a snapshot and then conversion itself. Please let the 2nd stage run.
