screwturner
Thu Oct 03, 2024 5:30 pm
I want to migrate a Hyper-V VM to ESXi the process seems simple but I'm a little confused about that happens after I click "finish". I will run the converter locally on the VM to avoid any access issues. When I click "finish" does V2V converter power down the source VM and do a final sync? Is the destination VM powered up automatically? Is there anyway that the VM could cutover to the destination side without intervention?
The documentation is great up and until the cut over, I just do understand where I'll be when I finish.
Fri Oct 04, 2024 5:23 pm
Welcome to StarWind Forum. V2V converter neither shuts down the source VM nor starts the destination automatically. This feature might be introduced in the future builds.
screwturner
Sat Oct 05, 2024 5:19 pm
yaroslav (staff) wrote: ↑Fri Oct 04, 2024 5:23 pm
Thanks for your quick response. I guess my next question would be once I hit finish is the cutover procedure is to shutdown the source and power on the destination? That's it? Where is the final sync?
Agrat2000
Fri May 30, 2025 1:57 am
That's a great question — I'm actually dealing with the same issue. Thanks for bringing it up!
