Starwind witness node corrupted
Chinny
Wed Oct 02, 2024 10:12 am
In our situation we have 3 servers and created a Starwind VSAN 2 node setup with a extra SW node. Node 1&2 contains the VSAN and the Node 3 acts as a witness node only.
However, due to unknown reasons, i cannot reach the management web page anymore of the witness server. We have spent alot of time trying to find out what the problem is on the witness server, but I figured it would be easier to recreate the witness server with the OVA deployment. Right now, the witness server is recreated with a empty Starwind configuration.
Node 1 & Node 2 are syncing toward each other and is synchronized and are online right now. The iSCSI is also available in VMWare. They are also communicating towards the witness server and i can see Node 1 and Node 2 are trying to reach the target of the witness server.
To minimize downtime, How can I recreate the witness node on the witness server with powershell without affecting node 1 & 2?
Any help would be greatly appreciated!
Wed Oct 02, 2024 10:59 am
Did you delete the old files from the storage (i.e., the OS disk and the headers)?
Chinny
Wed Oct 02, 2024 12:14 pm
yaroslav (staff) wrote: ↑
I dont know what you mean, I still have the old witness server VM with the configuration, yes. I just disabled the ethernet adapters for now.
Then created a new witness server VM with a empty configuration, the management page works on this VM.
If I understood you wrong, What do you mean exactly or which paths do you mean?
Wed Oct 02, 2024 3:07 pm
Go into that Witness server and copy
1. StarWind.cfg
2. Headers from /opt/starwind/starwind-virtual-san/drive_c/starwind/headers
3. *.swdsk.bak files (only you know where you created those. might be some /dev/sdb1/ path)
Chinny
Tue Oct 08, 2024 9:10 am
We could not find the headers file/folder, do you know another path where those files could be?
Maybe its because we're using a older version of Starwind
Tue Oct 08, 2024 12:07 pm
Greetings,
Look for them in /mnt/*.
tomhiddleston
Tue Oct 08, 2024 1:57 pm
To recreate the witness node on your Starwind setup without affecting Nodes 1 and 2, you can use PowerShell to configure the witness node while ensuring minimal downtime.
Tue Oct 08, 2024 2:29 pm
That's absolutely right, but you need first to remove the Witness from the replication partners.
This being said, if the configs can be restored give it a try first.
Chinny
Wed Oct 09, 2024 6:42 am
Restoring the config and copying the swdsk file to the new witness VM has solved the problem for me, thank you very much for your assistance!
Wed Oct 09, 2024 9:02 am
You are welcome :)
