What must i do in Azure to convert from Azure to Vmware
paule24
Wed Aug 14, 2024 12:53 pm
I am new on this. I need dokumentation what must be done in Azure to become Access from StarWind V2V Converter to azure.
Is there any documentation with the steps which must bee done.
Greetings Paul
paule24
Fri Aug 16, 2024 9:21 am
I have done this an i have connection to azure. But when i convert to vmware EsXI the following appears
This must be a fault becaues 117GB are not copied in seconds.
The vm was created on vmware but no boot.
paule24
Fri Aug 16, 2024 9:23 am
I only want convert from Azure to vcenter/esxi
paule24
Fri Aug 16, 2024 11:58 am
Please help me.
Fri Aug 16, 2024 12:23 pm
Please share the full conversion log with me they are in the here c:\Program Files\StarWind Software\StarWind V2V Converter\logs
paule24
Fri Aug 16, 2024 12:31 pm
OK here are logs.
I only want convert from Azure to vmware.
i have not createt a storage on Azure because i think this is only neccessary when i want copy from vmware to azure.
The log file name: 'logs\V2V_Log-20240816-091530.log' (PID 5556)
8/16 9:15:30.908 1430 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
8/16 9:15:30.908 1430 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
8/16 9:15:30.908 1430 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
8/16 9:15:30.908 1430 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
8/16 9:15:30.924 1430 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
8/16 9:15:30.986 1430 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - d4c0000
8/16 9:15:42.118 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAWSConnectionTo
8/16 9:16:27.954 1f04 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 9:16:32.204 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 9:16:52.205 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:37:10.424 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:37:17.506 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:37:22.445 1430 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eAWSConnectionTo
8/16 9:37:24.173 1f04 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 9:37:24.173 1f04 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
8/16 9:37:24.425 5d4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 9:37:28.325 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 9:37:35.676 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:39:55.350 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:39:59.132 1430 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eAWSConnectionTo
8/16 9:40:01.300 5d4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 9:40:01.300 5d4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
8/16 9:40:01.459 e60 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 9:40:06.016 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 9:41:51.475 1430 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 9:41:59.759 1430 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eAWSConnectionTo
8/16 9:42:02.522 e60 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 9:42:02.522 e60 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
8/16 9:42:02.663 1ab4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 9:42:35.022 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 9:43:04.085 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/16 9:43:11.179 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
8/16 9:46:29.225 1430 Facility ???INFO: WrapperESXI::connect: m_url - https://172.18.110.20/sdk
8/16 9:46:30.163 1430 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 52f216c1-3e0e-e13d-140c-6dac416fb2cc
8/16 9:46:30.163 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
8/16 9:46:30.448 1430 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
8/16 9:51:30.172 da0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
8/16 10:05:58.237 1430 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eESXConnectionTo
8/16 10:06:30.175 da0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
8/16 10:06:30.347 1430 Facility ???INFO: WrapperESXI::connect: m_url - https://172.18.110.20/sdk
8/16 10:06:30.409 1430 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 527d7548-967f-3c0b-a282-a376c60611ac
8/16 10:06:30.409 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
8/16 10:06:30.441 1430 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
8/16 10:06:57.957 1430 Facility ???WARNING: CPPVMSettingsESX::onNext: Don't finded . in [DX100S4-HDD-01] srv-dc01/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce
8/16 10:06:57.957 1430 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
8/16 10:06:57.957 1f0c Facility ???INFO: CPPConverting::Convert: InConvertType: 10, OutConvertType: 6
8/16 10:06:58.897 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 5
8/16 10:06:58.897 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 6
8/16 10:06:58.977 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 10
8/16 10:06:59.008 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 15
8/16 10:06:59.051 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 25
8/16 10:06:59.145 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 30
8/16 10:06:59.167 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 36
8/16 10:06:59.176 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 42
8/16 10:06:59.183 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 47
8/16 10:06:59.183 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 53
8/16 10:06:59.217 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 59
8/16 10:06:59.251 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 65
8/16 10:06:59.251 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 70
8/16 10:06:59.251 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 76
8/16 10:06:59.283 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 82
8/16 10:06:59.283 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 88
8/16 10:06:59.283 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 94
8/16 10:06:59.298 1f0c Facility ???INFO: WrapperESXI::Wait: Progress - 99
8/16 10:06:59.580 1f0c Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-40214
8/16 10:06:59.580 1f0c Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-40214
8/16 10:07:00.129 1f0c Facility ???INFO: CPPConverting::ConvertDisks: pathInput: /subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/trefflerundpartner/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce, pathOutput: [DX100S4-HDD-01] srv-dc01/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce.vmdk
8/16 10:07:00.380 1f0c Facility ???ERROR: VMConverter::AzureConverter::GetAccess: GetAccess Status code: 403 Error code: AuthorizationFailed Message: The client 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' with object id 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' does not have authorization to perform action 'Microsoft.Compute/disks/beginGetAccess/action' over scope '/subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/trefflerundpartner/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce' or the scope is invalid. If access was recently granted, please refresh your credentials.
8/16 10:07:00.380 1f0c Facility ???WARNING: AzureDisk::CreateInputImage: Disk is access
8/16 10:07:00.507 1f0c Facility ???ERROR: VMConverter::AzureConverter::RevokeAccess: RevokeAccess Status code: 403 Error code: AuthorizationFailed Message: The client 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' with object id 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' does not have authorization to perform action 'Microsoft.Compute/disks/endGetAccess/action' over scope '/subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/trefflerundpartner/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce' or the scope is invalid. If access was recently granted, please refresh your credentials.
8/16 10:07:00.507 1f0c Facility ???ERROR: AzureDisk::CreateInputImage: GetAccess is fail - Error sending request to Azure.
8/16 10:07:00.507 1f0c Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 2
8/16 10:07:00.507 1f0c Facility ???ERROR: CPPConverting::Convert: FAILED
8/16 10:07:42.520 5bc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
8/16 10:07:42.645 1ab4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 10:07:42.645 1ab4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
paule24
Fri Aug 16, 2024 12:34 pm
Here an other
The log file name: 'logs\V2V_Log-20240816-105336.log' (PID 1500)
8/16 10:53:36.141 15f0 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
8/16 10:53:36.141 15f0 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
8/16 10:53:36.149 15f0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
8/16 10:53:36.149 15f0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
8/16 10:53:36.149 15f0 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
8/16 10:53:36.149 15f0 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - d4c0000
8/16 10:53:52.328 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAWSConnectionTo
8/16 10:54:28.282 1e68 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 10:54:32.783 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 10:54:48.705 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:54:56.997 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:55:19.175 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:55:25.691 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:56:44.540 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:56:49.128 15f0 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eAWSConnectionTo
8/16 10:56:51.882 1e68 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 10:56:51.882 1e68 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
8/16 10:56:52.120 da0 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 10:56:56.385 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 10:57:07.434 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:58:30.351 15f0 Facility ???WARNING: CPPInputVM::onNext: Virtual Machine is running.
8/16 10:58:33.647 15f0 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eAWSConnectionTo
8/16 10:58:35.508 da0 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 10:58:35.508 da0 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
8/16 10:58:35.711 530 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
8/16 10:58:39.164 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/16 10:58:50.086 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/16 10:59:02.212 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
8/16 11:00:10.937 15f0 Facility ???INFO: WrapperESXI::connect: m_url - https://172.18.110.20/sdk
8/16 11:00:10.999 15f0 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 52a748ad-bda4-9139-9ade-12f4a715d57a
8/16 11:00:10.999 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
8/16 11:00:11.062 15f0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
8/16 11:01:23.341 15f0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
8/16 11:01:23.356 630 Facility ???INFO: CPPConverting::Convert: InConvertType: 10, OutConvertType: 6
8/16 11:01:23.404 630 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - Invalid datastore path '[DX100S4-HDD-01'.
8/16 11:01:23.436 630 Facility ???INFO: WrapperESXI::Wait: Progress - 5
8/16 11:01:23.436 630 Facility ???INFO: WrapperESXI::Wait: Progress - 6
8/16 11:01:23.515 630 Facility ???INFO: WrapperESXI::Wait: Progress - 10
8/16 11:01:23.531 630 Facility ???INFO: WrapperESXI::Wait: Progress - 15
8/16 11:01:23.563 630 Facility ???INFO: WrapperESXI::Wait: Progress - 25
8/16 11:01:23.690 630 Facility ???INFO: WrapperESXI::Wait: Progress - 30
8/16 11:01:23.713 630 Facility ???INFO: WrapperESXI::Wait: Progress - 36
8/16 11:01:23.721 630 Facility ???INFO: WrapperESXI::Wait: Progress - 42
8/16 11:01:23.721 630 Facility ???INFO: WrapperESXI::Wait: Progress - 47
8/16 11:01:23.737 630 Facility ???INFO: WrapperESXI::Wait: Progress - 53
8/16 11:01:23.785 630 Facility ???INFO: WrapperESXI::Wait: Progress - 59
8/16 11:01:23.801 630 Facility ???INFO: WrapperESXI::Wait: Progress - 65
8/16 11:01:23.807 630 Facility ???INFO: WrapperESXI::Wait: Progress - 70
8/16 11:01:23.807 630 Facility ???INFO: WrapperESXI::Wait: Progress - 76
8/16 11:01:23.838 630 Facility ???INFO: WrapperESXI::Wait: Progress - 82
8/16 11:01:23.848 630 Facility ???INFO: WrapperESXI::Wait: Progress - 88
8/16 11:01:23.864 630 Facility ???INFO: WrapperESXI::Wait: Progress - 94
8/16 11:01:23.864 630 Facility ???INFO: WrapperESXI::Wait: Progress - 99
8/16 11:01:24.147 630 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-40217
8/16 11:01:24.147 630 Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-40217
8/16 11:01:24.416 630 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: /subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/TREFFLERUNDPARTNER/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce, pathOutput: [DX100S4-HDD-01] srv-dc01.Riedelsberger.vmdk
8/16 11:01:24.588 630 Facility ???ERROR: VMConverter::AzureConverter::GetAccess: GetAccess Status code: 403 Error code: AuthorizationFailed Message: The client 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' with object id 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' does not have authorization to perform action 'Microsoft.Compute/disks/beginGetAccess/action' over scope '/subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/TREFFLERUNDPARTNER/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce' or the scope is invalid. If access was recently granted, please refresh your credentials.
8/16 11:01:24.588 630 Facility ???WARNING: AzureDisk::CreateInputImage: Disk is access
8/16 11:01:24.744 630 Facility ???ERROR: VMConverter::AzureConverter::RevokeAccess: RevokeAccess Status code: 403 Error code: AuthorizationFailed Message: The client 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' with object id 'cef560cf-c3b1-4462-80e3-baa2c5f2fcbc' does not have authorization to perform action 'Microsoft.Compute/disks/endGetAccess/action' over scope '/subscriptions/5c5c99d4-1a8a-40eb-aa5f-5ab4498e76de/resourceGroups/TREFFLERUNDPARTNER/providers/Microsoft.Compute/disks/srv-dc01_OsDisk_1_391615515e1d4fc79b770628be4e4dce' or the scope is invalid. If access was recently granted, please refresh your credentials.
8/16 11:01:24.744 630 Facility ???ERROR: AzureDisk::CreateInputImage: GetAccess is fail - Error sending request to Azure.
8/16 11:01:24.744 630 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 2
8/16 11:01:24.744 630 Facility ???ERROR: CPPConverting::Convert: FAILED
8/16 11:02:14.463 7c8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
8/16 11:02:14.476 530 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Event exit thread
8/16 11:02:14.476 530 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: End token control expires
Fri Aug 16, 2024 1:12 pm
There is a problem with the subscription account. I will take a look at it with R&D to see if the logs tell anything specific about the nature of the issue..
paule24
Fri Aug 16, 2024 1:17 pm
OK what can i do. i have copied this from Azure.
In V2V it works and i see the subscription and i can also klick the vm which i want to convert. This prozess works but no converting.
Fri Aug 16, 2024 1:41 pm
It is referring to the subscription in the log. Just a several more questions.
Could you please let me know which subscription you use?
What are the application settings?
Did you assign the role as described here https://www.starwindsoftware.com/v2v-he ... Azure.html?
paule24
Fri Aug 16, 2024 1:45 pm
Alle done
Tue Aug 20, 2024 8:19 pm
You need to create an application in Azure. You can get the credentials from it then.
You will need to connect an application to the role (Reader role as described here https://www.starwindsoftware.com/v2v-he ... Azure.html).
