VMware to Hyper-V > Mass migration and Live VM Migration
vince154
Wed Aug 07, 2024 2:26 pm
I'm planning to replace my old VMware Cluster by a brand new Cluster on Hyper-V with VMM
The cluster runs around 450 VMs.
As I'm looking for tools to convert VMs, I found pros and cons to each tools (based on information found on the Web)
  • VMM
    • Advantage : Integrated Management of VMware during the migration and optimized conversion time
    • Disadvantages :
      • One VM at a time
      • VM needs to be switched off (and Vmware tools uninstall) so long time of service breakdown
  • Veeam Backup
    • Advantage : Mass conversion with Instant Recovery feature
    • Disadvantages :
  • Starwind
    • Advantage :
      • Performing live VM Migration
      • Windows Repair mode allowing to remove VMware Tools after migration
    • Disadvantages :
      • One VM at a time (in GUI mode)
I'm very (very) interested in Starwind tool. I just looking for more accurate information about
  • Live VM Migration : How it works ? what are the prerequisites ? etc.
  • Command-line : is it possible to schedule a multiple-VM migration through a script ? If so, do you have any script example ?
Can you help me with the questions above and confirm the pros of the starwind solution ?
Wed Aug 07, 2024 2:48 pm
Thanks for your post!
The VM should have no snapshots.
V2V converter creates a checkpoint before creation, converts the disk and merges the snapshot at the end.
Mass conversion in GUI is to be introduced later. Now it is only one VM at a time.
Sadly, there is no ready-to-go script for conversion, yet, theoretically, you can use multiple CMD sessions to run several conversions at a time.
vince154
Thu Aug 08, 2024 10:16 am
Thanks for the reply. It helps a lot ! I think I would try the automatisation using the CLI.
After reading your comment, I guess that the source VM is automatically shutdown after the "first "conversion in order to merge the snapshot. Is that correct ?
I also read about the Windows Repair Mode after conversion for Windows VMs. What about Linux VMs ?
Thu Aug 08, 2024 10:42 am
You are always welcome!
No, the VM can continue running (I V2Ved a running VM last weekend).
Nerund86
Wed Mar 26, 2025 7:29 am
How does this V2V thing work?
Wed Mar 26, 2025 8:09 am
It converts the VMs and their disks between the hypervisors.
