starwind vsan powershell issue
fritte
Sat Jul 20, 2024 9:03 am
I tryed hours over hours to create a ha device again, but it fails, no matter what i change
param($addr="192.168.150.48", $port=3261, $user="root", $password="starwind",
   $addr2="192.168.150.49", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=1200,
	$sectorSize=512,
	$failover=0,
#primary node
	$imagePath="My computer\D",
	$imageName="masterImg23",
	$createImage=$true,
	$storageName="",
	$targetAlias="targetha21",
	$autoSynch=$true,
	$poolName="pool1",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=172.16.20.20:3260" -f $addr2,
	$hbInterface="#p2=172.16.10.20:3260,192.168.150.49:3260" -f $addr2,
	$createTarget=$true,
#secondary node
	$imagePath2="My computer\D",
	$imageName2="partnerImg24",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="partnerha22",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=172.16.20.10:3260" -f $addr,
	$hbInterface2="#p1=172.16.10.10:3260,192.168.150.48:3260" -f $addr,
	$createTarget2=$true
    Import-Module StarWindX
try
	Enable-SWXLog
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
200 Failed: invalid partner info..
im not sure whats going on, used the "CreateHA_2.ps1" as reference, but still fails
Windows Server 2019 Standard using StarWind VSAN Free 8.0.15469.0, i can connect to both starwind vsan instances with the limited gui and ping to all ip is going as expected, still starwind trows this non informational 200 failed error. it does create the .img file on the local machine, but not more happens
Thu Jul 25, 2024 4:02 pm
Greetings,
There are still references to Bitmap types in the script. Please remove those.
