VSAN Free CVM Lost license after Update to latest release
mstewart_83
Mon Jul 15, 2024 9:05 pm
I upgraded one node in a 2-node VSAN Free CVM cluster using the WebUI a few hours ago to the latest release. After completing the update and logging back into the WebUI, I got a message saying the license expired (see attached) and it appears the CVM storage config has been reset.
Here is a screenshot of the license expiration message:
Screenshot 2024-07-15 165420.png (127.65 KiB) Viewed 51533 times
Here is a screenshot of the message I get when uploading the license file. I get this message when trying to use the existing license and a new license file I downloaded today.
Screenshot 2024-07-15 164258.png (181.38 KiB) Viewed 51533 times
I have not upgraded the second node and it is working fine.
thomas84
Sat Jul 20, 2024 7:22 pm
Same problem here:
After rebooting my starwind vsan free appliances first time (version 1.6.558.7249) both appliances now show "license expired". - Is this a bug in the latest release !?
EDIT: It seems like perhaps only the web gui is acting strange !? - The solution itself seems to work totally fine, this is what i see in the starwind management console and in vmware vcenter. -So perhaps this is something which is only affecting the whole web gui, but not the starwind solution itself !?
EDIT 2: While migrating another vm to the starwind free vsan suddenly all esxi hosts lost connection to the starwind iscsi target and the starwind management console also now states "ha synchronization fail" - For the moment i will restore all my vms from my veeam backups to a non starwind datastore and wait on feedback in this thread.
Thu Jul 25, 2024 12:41 pm
Thanks for your post! Yes, these are the known issues of the build which is to be addressed in future builds.
Looks like there was a synchronization drop. Should not lead to the outage though. Please make sure the storage is connected from both nodes and the rescan script works well.
See https://www.starwindsoftware.com/resour ... 0835c59b6b for more details.
thomas84
Tue Jul 30, 2024 8:01 am
Can you estimate when the next build without this bug will be available? I would like to give Starwind another chance.
Tue Jul 30, 2024 9:48 am
You can use the Windows-based console in the meantime if you have the trial or NFR key.
I do not have the ETA for the fix, but the next build might be in early October.
smellcrackers
Fri Sep 13, 2024 3:38 am
yaroslav (staff) wrote: ↑
Great! You responded quickly to the issue. Easy solution to work on together.
Fri Sep 13, 2024 3:49 am
You are always welcome.
Fri Sep 20, 2024 3:24 pm
Did you try re-applying the key and updating to the latest build as described here https://knowledgebase.starwindsoftware. ... chine-cvm/?
thomas84
Thu Sep 26, 2024 2:50 am
Re-applying the key to the buggy VSAN free installation does not work, will try to start the update in the web gui as described.
EDIT:
Applied the update to both appliances, which did work. :-) - Now the license error popup is gone, i now see both appliances back in the web gui, which was not the case before the update. - But there is still something going on with license, and i still cannot re-apply the license file.
Thu Sep 26, 2024 6:50 am
Great news!
Please try a different free key. If the issue is still there, pull the logs and share them with me. Many thanks!
thomas84
Fri Sep 27, 2024 2:13 pm
unfortunately i see no way to get any other license key installed. - There is no "upload" option, where i can add a new license.
If i click the "license" button only the things happen, you see in the screenshots above. - But no possibility to add a new key at all.
Fri Sep 27, 2024 2:35 pm
Greetings,
Could you please pull the support bundles from this system?
thomas84
Sun Sep 29, 2024 2:23 am
i just uploaded the logs to my onedrive and sent a mail to support AT startwindsoftware.com .
I hope you will find the cause why i experience this license error.
Best regards
Thomas
Sun Sep 29, 2024 1:14 pm
Thanks! We will take a look at them in a good order.
