Issue with iSCSI target
evehodge
Fri Jun 28, 2024 10:00 am
I installed Starwind on Windows 10. I have an NFS share and an iSCSI share set up. I can connect to the iSCSI via Vmware ESX 3.0.1 fine. I create a VM on there and then I installed the OS. However, it doesn't work and I can't reach any of my volumes.
If I reboot the ESX server the connection comes back and everything is fine until I use it again. I am using a Dell XPS 14 9440 to connect to the starwind with the SW iSCSI initiator.
Is there anyone having the same issue? Any advice?
Fri Jun 28, 2024 10:27 am
Welcome to StarWind forum.
SrtarWind VSAN is not supported on desktop OS (see more at https://www.starwindsoftware.com/system-requirements).
Did you create the VM on top of the iSCSI-connected storage?
Make sure to create an iSCSI volume not an NFS one to reach it over iSCSI.
Please elaborate on what exactly does work.
StarWind iSCSI initiator is a legacy product. Use MS iSCSI Initiator.
