dijsil
Mon May 27, 2024 7:40 am
At work I am doing a changeover from Vmware 7 to hyperv 2022 and used this software to do the migration.
I managed to transfer a VM successfully without errors however the 2nd (windows) and 3rd (linux) machines I am getting same error
I switched off the VM and did the conversion however when starting I am getting the below error.
Any ideas?
- Capture.JPG (85.59 KiB) Viewed 12382 times
dijsil
Mon May 27, 2024 8:21 am
thanks for the quick reply, downloaded file and transferring the vm again: fingerscrossed:
dijsil
Wed Jun 05, 2024 8:10 pm
I am trying to convert a redhat however am getting it to boot into emergency mode :S
- Capture.JPG (36.57 KiB) Viewed 12243 times
Wed Jun 05, 2024 9:49 pm
Please check the logs and see what exactly they are pointing to.
Maybe, there is some mount point missing in /etc/fstab
Boot from an iso and see if you can browse the boot volume file system.
