Veeam Hardened Repository..
tryllz
Sat May 25, 2024 12:10 pm
I wanted to know when setting up Backup Repository which is a VHR, can this be done over the Management interface only ?
I have Starwind with 2 interfaces, 1 is 1Gbps (Management, 10.11.30.178) and other is 10Gbps (Replication, 10.11.40.178).
I can access VHR user over the Management Interface, but when trying to access over the Data interface I get the below errors..
Sat May 25, 2024 2:30 pm
Make sure you allowed ssh in the VM.
tryllz
Sat May 25, 2024 5:10 pm
SSH is allowed as it works over 1Gbps..
tryllz
Sat May 25, 2024 6:32 pm
Found this to be a Asymmetric Routing issue, which was disabled in the Fortigate Firewall..
Enabled it as below in Fortigate
config system settings
    set asymroute enable
end
And its now SSH is reacahable..
Mon May 27, 2024 6:02 am
Thanks for your update. Did the error go away now?
tryllz
Mon May 27, 2024 6:57 am
yaroslav (staff) wrote: ↑
Yes, I can confirm the error went away.
Mon May 27, 2024 7:07 am
