ESXi to Hyper-V Convert Fails
rotech
Thu May 09, 2024 3:28 pm
Getting the following when trying to convert ESXi to Hyper-V, any assistance is appreciated!
The log file name: 'logs\V2V_Log-20240507-090223.log' (PID 6028)
Delete log file 'logs\V2V_Log-20240413-163552.log'.
5/7 9:02:23.956 1c80 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
5/7 9:02:23.956 1c80 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.444
5/7 9:02:23.972 1c80 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
5/7 9:02:23.972 1c80 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
5/7 9:02:23.972 1c80 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
5/7 9:02:23.972 1c80 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - e9580000
5/7 9:07:48.955 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
5/7 9:07:57.778 1c80 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocation
5/7 9:08:11.531 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
5/7 9:08:58.528 1c80 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.1.15/sdk
5/7 9:08:58.557 1c80 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 524ebb67-4844-fbda-0d47-6add33cb6d71
5/7 9:08:58.557 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
5/7 9:08:58.635 1c80 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
5/7 9:09:17.999 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
5/7 9:09:24.426 1c80 Facility ???INFO: CPPSynchronization::onNext: Synchronization for - [
5/7 9:09:24.427 1c80 Facility ???INFO: CPPSynchronization::onNext: Synchronization for - [
5/7 9:09:24.427 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
5/7 9:09:29.689 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
5/7 9:09:32.088 1c80 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
5/7 9:09:32.135 1c80 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
5/7 9:09:32.135 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
5/7 9:12:44.204 1c80 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
5/7 9:12:44.204 ca4 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
5/7 9:12:44.220 ca4 Facility ???INFO: WrapperESXI::Wait: Progress - 0
5/7 9:13:31.030 ca4 Facility ???INFO: WrapperESXI::Wait: Progress - 50
5/7 9:13:31.577 ca4 Facility ???INFO: WrapperESXI::Wait: Progress - 100
5/7 9:14:25.608 16f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
5/7 9:14:25.608 ca4 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Virtual Machines] Anderson-LOB/Anderson-LOB_1-000003.vmdk, pathOutput: V:\Hyper-V\Anderson-LOB\Virtual Hard Disks\Anderson-LOB_1-00000.vhdx
5/7 9:14:25.639 ca4 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Virtual Machines] Anderson-LOB/Anderson-LOB_1-000003.vmdk
5/7 9:14:25.639 ca4 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=1
5/7 9:14:25.655 ca4 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - D8:B6:1A:A3:95:CD:3C:6B:5D:30:E9:6B:4D:94:1A:3E:B1:F7:44:93
5/7 9:14:26.751 ca4 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
5/7 9:14:27.505 ca4 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
5/7 9:34:25.614 16f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
5/7 12:47:10.809 ca4 Facility ???INFO: CPPConverting::ConvertImage: Success
5/7 12:47:10.809 ca4 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [15K Spindle] Anderson-LOB-000003.vmdk, pathOutput: V:\Hyper-V\Anderson-LOB\Virtual Hard Disks\Anderson-LOB-00000.vhdx
5/7 12:47:10.809 ca4 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [15K Spindle] Anderson-LOB-000003.vmdk
5/7 12:47:10.809 ca4 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=1
5/7 12:47:10.825 ca4 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - D8:B6:1A:A3:95:CD:3C:6B:5D:30:E9:6B:4D:94:1A:3E:B1:F7:44:93
5/7 12:47:11.879 ca4 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
5/7 12:47:12.632 ca4 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 0
5/7 14:17:17.776 ca4 Facility ???INFO: CPPConverting::ConvertImage: Success
5/7 14:17:17.776 ca4 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
5/7 14:17:17.776 ca4 Facility ???ERROR: WrapperESXI::getArrayMorDatacenter: IsValidResponse childEntity false
5/7 14:17:17.776 ca4 Facility ???ERROR: WrapperESXI::getVMList: getArrayMorDatacenter is fail - -1
5/7 14:17:17.776 ca4 Facility ???ERROR: VMConverter::ESXIConverter::GetVMListInfo: getVMList fail - -1
5/7 14:17:17.776 ca4 Facility ???WARNING: CPPConverting::Synchronization: GetVMListInfo is fail
5/7 14:17:17.776 ca4 Facility ???WARNING: CPPConverting::Synchronization: Not found input vm - 1
5/7 14:17:17.776 ca4 Facility ???ERROR: CPPConverting::ConvertDisks: Synchronization - 2
5/7 14:17:17.839 ca4 Facility ???ERROR: WrapperESXI::removeSnapshot: RemoveSnapshot_USCORETask fail - 12
5/7 14:17:17.839 ca4 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
5/7 14:17:17.839 ca4 Facility ???ERROR: VMConverter::ESXIConverter::DeleteSnapshot: removeSnapshot fail - 12
5/7 14:17:17.839 ca4 Facility ???WARNING: CPPConverting::DeleteSnapshot: Error deleting snapshot - The session is not authenticated.
5/7 14:17:17.839 ca4 Facility ???ERROR: CPPConverting::Convert: FAILED
5/7 14:41:15.271 1c80 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
5/7 14:41:15.271 1c80 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
Sat Sep 14, 2024 8:28 pm
Sorry for such a delay.
Before running the converter, please merge the snapshots for that VM.
It appears to be an authentication issue on the ESXi side. Conversion is taking too long and the process hits the natural ESXi logout. You can try:
1. Converting the VM disks as the local file on Hyper-V. Copy the VMDK to Hyper-V and convert it there.
2. Tweak the timeout window https://docs.vmware.com/en/VMware-vSphe ... C6694.html.
3. Convert VM to OVF.
p.s. update your V2V converter.
