Multipath -ll no results
coffeeboy
Wed May 08, 2024 4:31 pm
I'm attempting to set up a small trial of the vSAN software in a 2 node Proxmox environment. I've followed the guide (https://www.starwindsoftware.com/resour ... ng-web-ui/) but I'm stuck at the last few steps.
Action 13 says the following:
Create LVM PV on multipathing device:
 pve# pvcreate /dev/mapper/mpatha
where mpatha – alias for StarWind LUN
However, when I run step 11 (multipath -ll) I get no results. Up to this point everything seemed to go as the document described.
root@pve:~# multipath -ll
root@pve:~#
I've rebooted the host but the same occurs.
Interestingly, I can connect to the LUN from my Windows PC so it really seems like a Proxmox issue.
coffeeboy
Thu May 09, 2024 10:00 am
OK so a bit more digging lead me to this command:
multipath -v3
which showed the following devices on PVE1
===== paths list =====
253d100e593e1934d                      6:0:0:0    sdb     8:16  -1  undef undef  STARWIND,STARWIND
       unknown
On PVE2 however, it was slightly different:
          unknown
253d100e593e1934d                         7:0:0:0    sdc     8:32  50  undef undef  STARWIND,STARWIND
          unknown
I've had to heavily edit the output as the anti-spam kept blocking it.
Not sure why the second node shows 2 iSCSI devices. Any way, I added the correct WWID to the Multipath config on both nodes it seems I added the wrong WWIDs previously. Now I have been able to complete the config.
Thu May 09, 2024 11:43 am
Thanks for your update and for sharing your experience. Glad to read you sorted it out. Can I help you with anything else?
coffeeboy
Mon May 20, 2024 9:11 am
Why do you think that one node has two paths, but the other has only one?
Mon May 20, 2024 9:27 am
Can you please share the answer for the follsing?
  • Can I please have the screenshot that showcases the full target name?
  • Are HA devices replicated?
  • How many links do you connect the storage with?
