Cannot authenicate to OLVM
fredtw0
Mon Apr 29, 2024 7:54 pm
While Oracle Linux Virtualization Manager is largely based on oVirt, it's not quite the same.
I am testing V2V from vCenter to OLVM with Oracle Linux KVM.
I can certainly authenticate and set up the vSphere source just fine; however, I tried to authenticate using the ovirt option to a test environment with the default admin account, as well as admin@internal. Also, i attempted directly to the host with root. None of these authenticate.
Is there a pre-existing method I am missing?
OR
Is this a feature that can be added? (vSphere -> OLVM migrations)
Tue Apr 30, 2024 7:36 am
Use credentials you use to log into oVirt Engine (I.e., https://test-ovirt-engine.tl.local/ovirt-engine)
fredtw0
Tue Apr 30, 2024 8:13 pm
Alrighty...
I tried to place
https://<olvm-fdqn>/ovirt-engine/
in the host box, then I attempted both
admin
and
admin@internal
with the appropriate password. Unfortunately it is still failing to connect with:
"Host Name or Credentials are wrong!"
Sun May 05, 2024 6:23 pm
Greetings,
Sorry for the delay. Can you try something like admin@ovirt@internal?
