Starwind cluster shutdown with Eaton IPM 2.7.x
it7119
Sat Apr 13, 2024 11:26 am
Hi all,
Has anyone had success with shutting down the Starwind cluster using Eaton IPM 2.7.x version recently in a controlled manner
My expected shutdown procedure i want in my environment is
1.Loss of mains power
2.Hypervisors run on UPS
3.When the run time on the UPS reaches X minutes
4. The VM's are shutdown in their preferred order
5. The storage cluster is put in maintenance mode ( how can this be done)
6. Then the hypervisor is then shutdown
The Eaton IPM is capable of running scripts, so i am wondering when the VM's are turned off how can the script be executed to put the CSV is maintenance mode.
Many thanks
Sat Apr 13, 2024 12:35 pm
Welcome to StarWindd Forum. Eaton should do well, I think. You can use this script to automate shutdowns.
viewtopic.php?f=5&t=4940
https://www.starwindsoftware.com/resour ... ?pdf=17913 (skip to the script :))
walkerlifter
Tue Jun 11, 2024 4:09 am
Worked for me!
Thu Sep 12, 2024 6:12 pm
We're happy to hear about that :)
Worked for me!
