Synchronization issue in new 3 node cluster
prismsoftware
Thu Apr 11, 2024 6:23 pm
Hi - I created a test 3 node cluster using the exact number of NICs/IPs as the example on the starwind site. Everything was working normally and there were no issues during creation. I tried to simulate a single node failure by rebooting the physical server (Node 1). Now I'm in a state where Node 2 says it's synchronized, Node 3 is trying to sync from Node 1 and failing with "synchronizer has invalid state", Node 1 is trying to establish a connection to Node 3 and can't (error 0x5b4)
I'm guessing that the nodes need to try and sync from Node 2 instead? I tried the syncDeviceAdvanced.ps1 script, on Node 1 it doesn't come back, Node 2 says synchronized and Node 3 reports:
Failed to perform synchronization (1) from iqn.2008-08.com.starwindsoftware:uzol1-uzol1targetalias
control 0x0000015B326E3A00 -Synchronize: -SynchronizationType:"1" -SynchronizerTargetName:"iqn.2008-08.com.starwindsoftware:uzol1-uzol1targetalias"
200 Failed: synchronizer has invalid state..
I'm not sure how to avoid this situation in the future - any ideas? I attached the powershell script I used. I can ping each node from Node 1, 2, 3 through the interfaces defined. Thank you very much.
CreateHA_TEST.zip
(1.43 KiB) Downloaded 5475 times
Thu Apr 11, 2024 10:52 pm
Welcome to StarWind Forum. Create a HA device without a write-back cache (comment caching areas) and repeat the tests.
prismsoftware
Fri Apr 12, 2024 3:40 pm
Hi Yaroslav - thanks for responding. I removed the cache and so far it appears to be working, after creating from scratch I tried the same thing (turning off a node) and it appears to be synchronizing after rebooting. Just so I understand can you explain why having a write-back cache defined caused an issue?
Fri Apr 12, 2024 11:25 pm
Write-back cache triggers full sync in case of one server's outage. Also, devices with Write-Back cache tend to end mutual not synchronized more often.
See more
caching https://knowledgebase.starwindsoftware. ... rinciples/,
full sync causes https://knowledgebase.starwindsoftware. ... may-start/.
How to fix mutual not synchronized https://knowledgebase.starwindsoftware. ... -blackout/
This concept can also be interesting https://knowledgebase.starwindsoftware. ... a-devices/
necktielunar
Thu May 23, 2024 7:31 am
It's great to be able to participate in discussing Virtual HCI Appliance (VHCA) topics. The website provides a lot of interesting information.
Thu May 23, 2024 7:40 am
You are welcome. You can always reach out to us at support@starwind.com to schedule a tech call to find out more about the solution.
